Part Number: DP83848Q-Q1
Other Parts Discussed in Thread: ETHERNET-SW
Hi Team
Would you help provide the RTOS driver for DP83848Q-Q1? Only Linux driver can be found in below website link?
ETHERNET-SW Driver or library | TI.com
Hi Team
Hi Ted,
My team is looking into this query. Please note that DP83848 is an older device and support is very limited.
Sincerely,
Gerome
Hi Gerome
Thanks for your quick response.
If will the RTOS driver of DP83848Q-Q1 be provided? If yes, would you share your the schedule? My customer will use DP83848Q-Q1 in the cockpit for Volvo and need the RTOS driver for MCU software development.
Hi Ted,
Which host MCU & SDK are being used? RTOS driver structure for 848 will vary between Hosts & SDK versions, so it is unlikely for us to provide an 848 RTOS driver directly compatible with non-TI MCU.
I recommend this procedure for integration:
1) Identify PHY driver structure & API requirements within the desired MCU SDK. Ideally there are existing PHY drivers in this SDK for reference.
2) Port 848 driver into MCU SDK as per structure identified in (1). Linux driver is a useful reference for key registers and function logic.
Please let me know any gaps or challenges for this procedure.
Thank you,
Evan
