LMH1297: simulation file (IBS, AMI, DLL)
Part Number: LMH1297
Other Parts Discussed in Thread: TDP0604,
Your portal does not currently list the IC TDP0604, so I selected the LMH1297 to proceed with the support request.
Could you please confirm whether the simulation files (IBIS and AMI DLL) for the TDP0604 can be used with HyperLynx, or if they are only compatible with Keysight ADS?
Thank you for your assistance.
Lionel
  • Lionel
    We only verify TDP0604 IBIS AMI model with Keysight ADS simulator, we never verified it with the HyperLynx simulator.
    David
  • Hi David,
    The IBIS file is referencing files that are missing from the snlm259.zip package available on the TI website.
    The following errors are reported during the IBIS model import:
    • ERROR (line 90): Code file Redriver_Signal_Path_x64.dll not found.
    • ERROR (line 90): Parameter file Redriver_Signal_Path.ami not found.
    Could you please confirm which files should be used as replacements?
    Available files in the package are:
    • Thru_x64.dll
    • Thru.ami
    • RX_Signal_Path_x64.dll
    • RX_Signal_Path.ami
    Please advise on the correct file mapping.
