TUSB211A-Q1: Ferrite Bead
Part Number: TUSB211A-Q1
One more follow-up regarding the TUSB211A-Q1 reference schematic
The datasheet specifies a ferrite bead of 100ohm @ 100MHz on the VCC supply. We are unable to source an exact 100ohm @ 100MHz part
Is 120ohm @ 100MHz acceptable as a substitute on the TUSB211A-Q1 VCC, or is the 100ohm value critical for proper device operation? If a specific tolerance range is acceptable (e.g., 80–120ohm), please advise.
Thank you.
E. Torres
