DP83TC811S-Q1: TDA4VH-Q1 100Mbps network link failure - PHY selection issue
Part Number: DP83TC811S-Q1
Other Parts Discussed in Thread: TDA4VH-Q1, TDA4VH, DP83TC811, DP83TG720S-Q1, DP83TC815-Q1, DP83TC811-Q1
DP83TC811S-Q1  100BASE-T1  -  Connects to the SGMII port of TDA4VH-Q1 via 4-wire connection.  Does this 100-megabit PHY model DP83TC811S-Q1 prevent the problem of TDA4VH-Q1's i2362 10-100M SGMII ignoring the preamble byte, which could cause link failure?
TDA4VH errata in english:
J784S4, TDA4AP, TDA4VP, TDA4AH, TDA4VH, AM69A Processors Silicon Revision 1.0 (Rev. C)
i2362 page29
TDA4VH errata in chinese:
J784S4 AM69x TDA4VH TDA4AH TDA4VP TDA4AP J742S2 TDA4VPE TDA4APE 处理器 器件版本 1.0 (Rev. C)
 i2362   PAGE 26
    TI's 100BASE-T1 PHYs should not have the issue described in the errata.
    We advise against using DP83TC811. Instead please consider using DP83TC815, our newest 100M PHY with robust EMC.
    Charles
  • Hi
    Can DP83TC815-Q1 and DP83TC811-Q1 be designed with pin-to-pin compatibility? Additionally, if we choose the DP83TC811, we also need to ensure compatibility with the DP83TG720S-Q1. Can the DP83TC815 be made compatible with the DP83TG720S-Q1? Does TI provide any relevant design documentation for reference?
  • Hi Xiaomu,
    DP83TC811 cannot be designed p2p compatible with DP83TG720.
    yes. DP83TC815 can be designed for compatibility with DP83TG720. Please request access to the DP83TC815 secure folder for a common schematic design guide.
    Charles
