TUSB564: DP1.4 / CTS test fail
Part Number: TUSB564
Please find attached file, we use TUSB564(include redriver) for USBC(DP) to LT6911(CSI bridge).
LT6911 vender help us testing DP1.4(CTS) function and result has serval fail items. I also attached failure report. we want to adjust EQ(hardware,resistor) to improvement and fix these issue.
Could you help to review and recommend what the resistors can use? Thanks a lot.
0806.zip
TI_TUSB564_MUX schematic_20260806.pdf
  • Hi Tony,
    I'm reading through some of the tests and the fails dont make sense to me.
    For example 20mHz SJ RBR Lane 0 (TP2) does not have any bit errors, but is labeled as a fail.
    In the schematic, I see that we are GPIO mode, and ass the EQ registers are set to F. This may lead to overcompensation of the signal.
    Can you provide an approximation of the pre-channel and post-channel losses. This will help us tune the EQ for your system.
    Closing thread due to inactivity. If you have any follow-up questions or concerns, feel free to reply.
