Part Number: DP83867E
Hi team,
Customer Issue: Currently, there is a missing frame fault under certain conditions (motor is spinning). The customer manually changed the network cable because of a problem with the PHY analog side sequence of the board. The interference is now suspected to have increased after the motor is enabled, resulting in frame loss issues.
Does DP83867ERGZR have any register that indicates communication errors like bit errors, missing frames, and so forth on the analog side of the PHY?
Thanks.
Joyce
