DSLVDS1001-1002EVM: DSLVDS1001-1002EVM PCB Dimensions
Part Number: DSLVDS1001-1002EVM
Hi there,
Is there a STEP file available for this part please?
Alternatively, could you please provide the dimensions and location of mounting holes and connectors?
Ben
  • Hi Ben,
    I've tried exporting a step file from the PCB editor and attached it to this post, but i have no ability to really inspect it for accuracy.
    In case its not useful, the mounting holes are centered 2260 mils apart from each other on the width, and 3010 mils apart lengthwise. The board itself is 3450x2700mils. The hole size is 125mils. The coordinates are shown below, note that the bottom right mounting hole in that image actually appears to be 10 mils further left (at 2470 on the x axis), than the hole above it (2480mils on the x axis).
    Brandon Fisher
    https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/138/HSDC046A.step
  • Hi Brandon,
    That's perfect, thank you very much for the prompt response!
    Ben
