TPD2S703-Q1: application question
Part Number: TPD2S703-Q1
Hi team,
May ask TPD2S703QDGSRQ1 if the interface IC D+ D- can be exchanged?Can the D+ signal from USB attache to the D- of the chip? Thanks!
BR
Jiawei
Suggest a better translation
  • Hi Jaiwei,
    The TPD2S703 does not support any charge port negotiation, so it is possible to exchange the ports as long as you exchange both the D_/- and VD+/- ports.  This will ensure that the bus maintains the correct connection to the connector and IC.
    Chuck
