Part Number: USB-TO-GPIO2
Previously purchased devices with the same model code can all transmit data normally, but the most recently purchased unit fails to do so
Hi Linh,
Could you please describe your issue in a little bit more detail? What kind of error are you seeing? Can you clarify what you mean by "the most recently purchased unit fails to do so?"
Jonathan
The device I just bought has very slow data transfer speeds, which don't match the specifications published for the device. I think the problem lies in the device's hardware
Hello Linh,
Ensure to enable the pull-ups on the USB2GPIO. If it is set to open-drain, starting up the GUI will be very slow, I believe new systems will have the integrated pull-up resistors to open-drain, which can make things very slow.
Luis Hernandez Salomon
