TS3DV642-Q1: Requesting for VIH, VIL, VOL, VOH values
Part Number: TS3DV642-Q1
We are currently evaluating the noise margin of the TS3DV642-Q1. To help with our calculations, could you please share the VOL and VOH values for the control pins, as well as the VIH, VIL, VOH, and VOL values for the data pins?
  • Hello Swetha,
    VIH and VIL can simply be found in the datasheet, see below:
    The control pins are only inputs, we don't specify VOH and VOL.
    This is a passive mux, it just passes signals along. The data pins, which I am assuming you are referring to the I/Os don't have these values.
    Nir
