TPS1685: Inquiry regarding hardware design compatibility between TPS1685 and TPS1686
Guru 12875 points
Part Number: TPS1685
Other Parts Discussed in Thread: TPS1686,
My customer has an inquiry regarding hardware design compatibility between the TPS1685 and TPS1686.
Although the two products feature different packages—LQFN-CLIP and VQFN— the customer reports that they are very similar in terms of actual pin mapping and packaging size, with the exception of the Pin 12 definition.
Is it acceptable for users to use a single hardware design (PCB layout) to ensure compatibility between two products?
Thanks in advance.
JH
