Part Number: DP83826AE
Dear,
Customer found that two boards failed PHY communication during testing.
Read register status, Link Status register value is 0 (Link not established);
MDI/MDIX Mode is 1(MDI Pairs swapped), Normal is 0 (MDI Pair normal, not swapped).
Using VNA to test the RD TD impedance, it was found to be outside the normal range. Appears to continuously jump between normal and abnormal values after being powered on. The test results are shown in the attached video.
SCH:
Pls help to review and give advise locate the issue, thanks!
