DS90UB960-Q1: MIPI-CSI
Part Number: DS90UB960-Q1
Other Parts Discussed in Thread: DS90UB953-Q1, DS90UB9702-Q1, DS90UB971-Q1, DS90UB940N-Q1, DS90UB929-Q1, DS90UB949-Q1, DS90UB947-Q1, DS90UB964-Q1, DS90UB962-Q1, DS90UB940-Q1, DS90UB9722-Q1
Hello, I am Juan, from Rother.
We are currently developing an automotive application based on a smart module and are evaluating an automotive serializer/deserializer (SerDes) solution to connect multiple cameras.
We have been considering the DS90UB960-Q1 deserializer and its compatible automotive serializers. However, before selecting the components, we would appreciate your technical advice on the most suitable architecture for our application.
1. SMART MODULE MIPI CSI-2 interface specifications and limitations
According to the information provided by the manufacturer, the smart module has the following characteristics:
  • Two MIPI CSI-2 camera interfaces.
  • D-PHY v1.2 (receive-only) and C-PHY v1.0 support.
  • Maximum data rate of 2.5 Gbps per lane, with up to 10 Gbps per four-lane interface.
  • Maximum still-image resolution of 21 MP in snapshot mode.
  • Supported recording modes: 1080p at 30 fps and 720p at 30 fps. A 480p at 120 fps high-frame-rate mode requires a feature request.
  • Supported pixel formats: RAW8, RAW10, RAW12, NV12, NV21 and JPEG.
They has also confirmed that the current smart module SDK and camera driver do not support CSI-2 virtual-channel (VC) demultiplexing. Consequently, multiple camera streams cannot currently be captured and handled independently when they are transmitted simultaneously through a single CSI-2 interface using different virtual channels.
We are therefore investigating architectures that would allow us to use the smart module's two physical CSI-2 interfaces without relying on simultaneous VC demultiplexing on either interface.
2. Architecture A – Four cameras with one selected output stream
Our first proposed architecture would use four cameras, each connected to a dedicated serializer. All four serializers would connect to a single deserializer.
The deserializer would select one camera at a time and forward only that camera's video stream through one MIPI CSI-2 output connected to one of the CQS290's CSI-2 interfaces.
The intended operation would be to switch between the four cameras as required, without transmitting multiple camera streams simultaneously over the same CSI-2 interface.
We would like to know whether the DS90UB960-Q1 can be configured to support this operating mode and whether you foresee any relevant limitations when switching between camera inputs.
3. Architecture B – Four cameras distributed across two CSI-2 outputs
Our second proposed architecture would also use four cameras and four serializers connected to a single deserializer, but would make use of both CSI-2 output ports.
The intended configuration would be:
  • Two cameras assigned to CSI-2 output 0, with the ability to select and forward one of those two cameras at a time.
  • The other two cameras assigned to CSI-2 output 1, again with the ability to select and forward one camera at a time.
  • CSI-2 output 0 connected to the CQS290's CSI-0 interface.
  • CSI-2 output 1 connected to the CQS290's CSI-1 interface.
This would allow one camera to be selected on each output, potentially enabling two independent camera streams to be received simultaneously by the smart module, one through each physical CSI-2 interface.
As the smart module does not currently support VC demultiplexing, we would need the selected camera on each output to be delivered in a configuration compatible with the corresponding smart module CSI-2 receiver, without requiring it to separate multiple simultaneous VC streams on that interface.
Could you please confirm whether the DS90UB960-Q1 supports this configuration and advise how the input-to-output routing and stream selection should be implemented?
4. Recommended automotive SerDes solution
We initially identified the DS90UB960-Q1 because it provides four camera inputs and two MIPI CSI-2 output ports. However, we have not yet committed to this component.
Considering the smart module specifications and the limitations described above, we would appreciate your recommendation on the most appropriate automotive-qualified serializer/deserializer solution for our application.
In particular, we would be interested in your advice on:
  • Whether the DS90UB960-Q1 is suitable for either of the proposed architectures.
  • Which compatible automotive serializers you would recommend.
  • Whether another TI automotive deserializer and serializer family would be more appropriate, particularly if it offers greater bandwidth or better support for higher-resolution cameras.
  • The maximum supported camera resolution, frame rate and pixel formats for the recommended solution.
  • The available CSI-2 output lane configurations and maximum data rate per lane.
  • Any relevant limitations concerning camera selection, switching between inputs, simultaneous operation of both outputs or compatibility with the smart module.
Our goal is to implement a reliable automotive multi-camera system while preserving the required image quality and ensuring compatibility with the samrt module's CSI-2 interfaces.
We would be happy to provide additional details about the intended camera sensors once the most appropriate SerDes architecture has been identified.
Thank you in advance for your technical assistance and recommendations.
Juan
  • Hi Juan,
    Both architectures are supported by the DS90UB960-Q1. Our recommendations are below.
    1. Routing and stream selection
    The 960 provides independent forwarding controls for all four RX inputs. Register 0x20 selects each input’s destination, TX0 or TX1, and enables or disables its forwarding.
    For Architecture A, enable only one RX toward TX0. For Architecture B, enable one RX toward each output. The other FPD-Link connections can remain running without forwarding their video.
    2. VC configuration and camera switching
    Present the selected stream using a consistent VC accepted by the receiver, such as VC0. Each physical output may independently use VC0. For CSI-2 inputs, per-RX VC remapping is available through register 0x72.
    To switch cameras, disable the old input’s forwarding before enabling the new input. Disable forwarding before changing an input’s output assignment. Keep the CSI transmitter enabled where possible.
    The receiver driver must tolerate the transition and wait for a complete valid frame; seamless switching is not guaranteed. Matching camera formats simplifies switching. Changes in resolution, data type or bit depth may require receiver/ISP reconfiguration.
    If a camera itself outputs multiple image VCs, such as HDR exposures, those streams require separate consideration.
    3. Recommended automotive SerDes options
    DS90UB953-Q1 + DS90UB960-Q1: The FPD-Link III line rate is up to 4.16 Gbps per link. The serializer accepts up to four CSI-2 data lanes at 832 Mbps per lane. The deserializer provides two D-PHY CSI-2 outputs, each supporting 1, 2, 3 or 4 data lanes. The maximum output rate is 1.6 Gbps per lane with a 25-MHz reference clock, or 1.664 Gbps per lane with a 26-MHz reference clock.
    DS90UB971-Q1 + DS90UB9702-Q1: The FPD-Link IV line rate is up to 7.55 Gbps per link. The serializer accepts up to four CSI-2 data lanes at 1.5 Gbps per lane. The deserializer provides two main D-PHY CSI-2 outputs, each supporting up to four data lanes at 2.5 Gbps per lane, plus an additional replication output. This combination offers greater bandwidth for higher-resolution or higher-frame-rate cameras.
    4. Resolution, frame rate and pixel formats
    The maximum operating mode depends on bandwidth, packet size and timing rather than resolution alone. Documented examples include 2.3 MP/60 fps and 4 MP/30 fps for 953, while 971/9702 targets 8-MP-and-higher applications. These examples require confirmation against the actual sensor configuration.
    RAW8/10/12 and other supported CSI-2 formats can be transported without image-format conversion. The SerDes does not scale images or encode/decode JPEG. NV12/NV21 are generally processor-side memory layouts.
    JPEG transport requires confirmation of the camera’s CSI-2 encapsulation and the module driver’s support. Similarly, the module’s 21-MP snapshot capability does not independently establish that a particular sensor mode fits the SerDes link.
    5. Output configuration and module compatibility
    960 supports 1, 2, 3 or 4 data lanes per output; 9702 supports up to four per main output. Both use D-PHY for this connection.
    Both 960 CSI-2 outputs share the same PLL rate setting, while their lane counts can be configured independently.
    Confirm the module’s supported lane rates, clock mode, data types and calibration behavior. For 9702, specifically verify its D-PHY v2.1 transmitter configuration against the module’s D-PHY v1.2 receiver requirements.
    For Architecture B, also confirm simultaneous dual-interface capture and processing. Higher SerDes bandwidth does not remove SDK or ISP limitations.
    6. Information needed to finalize selection
    Please provide each sensor’s transmitted resolution, frame rate, bit depth, data type, VC usage, lane count and lane rate, including HDR or embedded data. Please also confirm the acceptable switching interruption.
    These details will determine whether 953 + 960 is sufficient or the higher-bandwidth 971 + 9702 solution is needed, and allow us to define the corresponding configuration.
    Yue
  • Hi Yue,
    Following our previous discussions regarding the SerDes solutions, we would like to explore an additional architecture for our automotive multi-camera system.
    Due to PCB scalability requirements, we are considering a modular camera architecture. Some customers will require camera functionality, while others will not. Therefore, we would prefer to keep the main PCB common across all product configurations and implement the camera system through external modules.
    1. Proposed modular architecture
    Our idea is to develop an external camera module consisting of:
    • One deserializer.
    • Up to four cameras, each connected to its corresponding automotive serializer.
    • The deserializer would aggregate the camera connections and provide a single output.
    This output would then be connected to an additional serializer, which would transmit the aggregated camera data to another deserializer located on our main PCB.
    The main PCB deserializer would receive the data from the external module.
    Our intention is to support up to four of these external camera modules, each containing one deserializer and up to four cameras with their corresponding serializers.
    Each external module would connect to one of the four inputs of the central deserializer on the main PCB.
    Conceptually, the architecture would look like this:
    External camera module (up to four cameras):
    Camera 0 → Serializer 0 ──┐
    Camera 1 → Serializer 1 ──┤
    Camera 2 → Serializer 2 ──┼── External Deserializer-----External Serializer-----Automotive link-----Main PCB:
    Camera 3 → Serializer 3 ──┘
                         Central Deserializer
                       RX0    RX1    RX2    RX3
                      Module  Module  Module  Module
                         0      1      2      3
    This would allow us to connect up to four external camera modules, potentially supporting a total of sixteen cameras, while keeping the main PCB design independent of the number of cameras installed.
    2. Technical feasibility
    We would appreciate your engineering team's assessment of whether this cascaded SerDes architecture is technically feasible using TI automotive serializer/deserializer devices.
    In particular, we would like to clarify the following:
    1. SerDes cascading: Is it possible to connect the CSI-2 output of an external deserializer to a serializer and then transmit the aggregated camera data to a second deserializer located on the main PCB?
    2. Multiple camera streams: Can the first deserializer aggregate the video streams from up to four cameras and forward them through a single serializer-to-deserializer link without losing the individual camera streams?
    3. Virtual channels: Can the camera streams maintain their individual VC-ID assignments throughout both SerDes stages? Are there any limitations concerning VC-ID remapping or the number of virtual channels supported across cascaded devices?
    4. Camera selection: Would it be possible to select and forward individual camera streams at either the external module or the main PCB deserializer, while keeping the other camera connections active?
    5. Bandwidth limitations: What would be the bandwidth limitations of this architecture? Would the second serializer/deserializer link be able to transport the aggregated data from four cameras simultaneously? How should the bandwidth be calculated across both SerDes stages?
    6. Electrical and physical compatibility: Are there any electrical, signal-integrity, clocking, synchronization or PCB layout limitations associated with cascading these devices? Are there any particular requirements concerning CSI-2 clock modes, lane configurations or reference clocks?
    7. Latency and image quality: Would this architecture introduce any significant additional latency or affect the original image quality? Can the video data be transported through both SerDes stages without image compression or format conversion?
    3. Recommended TI solution
    We initially considered the DS90UB953-Q1 + DS90UB960-Q1 combination, as well as the DS90UB971-Q1 + DS90UB9702-Q1 combination.
    However, considering this new modular architecture, we would appreciate your recommendation regarding the most suitable automotive-qualified serializer/deserializer components.
    In particular, we would like to know:
    • Whether any of the aforementioned devices support this cascaded architecture.
    • Whether you recommend a different serializer/deserializer family for this application.
    • Whether there are dedicated CSI-2 aggregation devices, camera hubs, CSI-2 controllers or other solutions that would be more suitable than cascading two SerDes stages.
    • Whether a different architecture would offer better bandwidth, scalability, latency and image quality.
    Our objective is to develop a reliable and scalable automotive camera platform that can support up to four external modules, each potentially containing four cameras, while maintaining the highest possible image quality and minimizing the complexity of the main PCB.
    We would greatly appreciate your technical recommendations and any reference designs or application notes related to this type of architecture.
    Thank you in advance for your support.
    Juan
  • Hi Juan,
    Thank you for the additional details. Connecting a deserializer’s CSI-2 output to another serializer is conceptually possible, provided the interfaces and configurations are compatible. However, this alone does not establish that the complete sixteen-camera system will meet its operating requirements.
    Please find our initial assessment below.
    1. SerDes cascading
    A deserializer’s CSI-2 output can serve as the input to a CSI-2 serializer. The lane count, lane rate, clock mode and timing must match. The complete two-stage configuration still requires assessment.
    2. Preserving multiple camera streams
    CSI-2 aggregation can preserve separate camera streams using distinct VC identifiers. The intermediate serializer and downstream deserializer must support those VCs, data types and the combined traffic.
    3. VC assignments and limitations
    VC identifiers can be preserved or remapped, depending on the devices and configuration. The 953 supports four VCs, while the 971 and 9702 support sixteen. The 960 supports four VCs per CSI-2 output.
    VC conflicts between modules, mixed-generation VC interpretation, and cameras using multiple VCs—for example, HDR exposures—must be considered throughout the chain.
    4. Camera selection
    At the external hub, individual cameras can be selected through per-RX forwarding controls while their links remain active.
    At the central hub, an RX now carries the combined streams of an external module. Normal RX forwarding controls select that complete input; they should not be assumed to provide independent filtering or routing of every VC within it. This part requires further review.
    5. Bandwidth
    Each stage must accommodate all streams transmitted through it simultaneously. The initial image-payload calculation is:
    Width × Height × Frame rate × Bits per pixel
    CSI packet overhead, embedded data, LP/HS timing and buffering must then be included. Each module uplink carries its aggregated traffic, and each central CSI output carries the combined traffic assigned to it. We cannot confirm four simultaneous cameras per uplink without their actual output configurations.
    6. Electrical, clocking, synchronization and layout
    Every CSI-2 connection must satisfy both devices’ electrical and timing requirements. The deserializer’s maximum output rate may exceed the following serializer’s input limit.
    Reference clocks, synchronous-link startup, FrameSync distribution, power sequencing and PCB signal integrity also require assessment.  establish the I²C, reset or GPIO paths between stages.
    An additional stage introduces reception, buffering, scheduling and transmission delay. A fixed end-to-end latency cannot be specified without the operating conditions.
    Compression, scaling or format conversion is not inherently required. Pixel data can be transported without those operations, subject to bandwidth and data-integrity requirements.
    8. Applicability of the devices mentioned
    The devices mentioned provide relevant CSI-2 serialization, deserialization and aggregation functions. However, their individual capabilities do not constitute validation of this complete cascaded topology. We have not yet confirmed a specific device combination and configuration for your system.
    9. Other SerDes families
    Whether another family would be more suitable depends on the simultaneous stream count, sensor bandwidth, VC requirements and control architecture. We would like to review these requirements with the team before identifying an alternative.
    10. Dedicated aggregation devices or controllers
    The 960 and 9702 already provide camera aggregation. Additional logic may be needed if the system requires functions beyond their documented capabilities, such as particular per-VC selection, routing or processing. We have not yet established whether an additional controller is necessary.
    11. Alternative architectures and scalability
    The trade-offs include uplink bandwidth, connector count, latency, power and software complexity. Also, the smart module’s previously stated lack of VC demultiplexing remains a limitation: transporting sixteen streams does not make them independently accessible to the current SDK.
    Please clarify whether sixteen cameras need to remain connected for selection, or whether all sixteen must be captured simultaneously.
    12. Reference cases and documentation
    The device datasheets and EVM guides describe the individual interfaces and configuration requirements. I do not currently have a validated reference case for this exact sixteen-camera, two-stage topology.
    This architecture involves several interacting constraints. I need to discuss it further with our team to identify any additional limitations or implementation challenges that may not be apparent from the individual device specifications. We will follow up after that review.
    Yue
  • Hi Yue,
    Thank you for your detailed assessment.
    We would like to clarify our intended camera operating modes and provide some additional information to help you continue evaluating the proposed architecture.
    1. System configuration
    Our current implementation will consist of one external camera module connected to the main PCB, with up to four cameras in total.
    The proposed architecture is as follows:
    • The external camera module will integrate one deserializer connected to up to four cameras, each with its own serializer.
    • The CSI-2 output of this deserializer will be connected to an additional serializer.
    • This serializer will transmit the aggregated camera data through an automotive SerDes link to a central deserializer located on the main PCB.
    • The central deserializer will provide the CSI-2 output(s) required to interface with the Cavli CQS290 module.
    Although the initial implementation will use only one external camera module, we would like to keep the main PCB architecture scalable, allowing up to four external modules to be connected in a future configuration.
    2. Camera operating modes
    Our preferred operating mode is to transmit all four camera streams simultaneously, with each camera identified by a separate CSI-2 Virtual Channel (VC), through the cascaded SerDes architecture.
    We have already contacted Cavli to determine whether the CQS290 hardware supports receiving and independently processing four simultaneous CSI-2 streams through its camera interfaces, and whether this functionality could be implemented through custom driver and SDK development, since it is not currently supported by the standard SDK.
    However, if the CQS290 hardware or software architecture does not allow simultaneous capture of all four streams, our alternative would be to keep all four cameras connected and active at the external deserializer, while selecting and forwarding only one camera stream at a time to the main PCB.
    We would therefore appreciate your evaluation of the SerDes architecture for both operating modes, giving priority to the simultaneous transmission of all four camera streams.
    3. Camera specifications
    We have not yet finalized the camera sensors and their operating configurations. Therefore, we would appreciate your recommendations regarding suitable camera configurations and the corresponding SerDes components.
    In particular, we would like to understand the maximum practical resolution, frame rate and bit depth that could be supported for four cameras through the proposed cascaded architecture.
    4. Requested evaluation
    Based on these requirements, could you please continue reviewing the proposed architecture and advise us on the following points?
    • Whether the proposed two-stage SerDes topology is technically feasible using TI devices.
    • Which serializer/deserializer combination you would recommend for the external camera module and the main PCB.
    • Whether the intermediate CSI-2 connection can reliably transport four independent camera streams using separate Virtual Channels.
    • Whether the proposed architecture can support simultaneous transmission of all four camera streams.
    • If simultaneous transmission is not feasible, whether individual camera selection at the external deserializer would be a suitable alternative.
    • The maximum aggregate bandwidth that could be supported through each stage.
    • Whether you recommend using one or both CSI-2 outputs of the central deserializer.
    • Any additional hardware, synchronization or control requirements that should be considered.
    If additional camera parameters are required to perform a more accurate bandwidth and compatibility assessment, please let us know exactly which specifications you need us to provide.
    Our objective at this stage is to establish a technically viable and scalable hardware architecture before selecting the final components and camera sensors.
    Thank you for your support.
    Juan
  • Hi Juan,
    Thank you for clarifying your requirements. Please find our responses below.
    1. Whether the proposed two-stage SerDes topology is technically feasible using TI devices.
    Yes. The proposed cascaded topology is feasible using TI FPD-Link IV devices, including simultaneous transport of four camera streams from an external module to the main PCB.
    2. Which serializer/deserializer combination you would recommend for the external camera module and the main PCB.
    A suitable starting point is:
    Each camera: DS90UB971-Q1 serializer.
    External module: DS90UB9702-Q1 quad deserializer, followed by a DS90UB971-Q1 uplink serializer.
    Main PCB: DS90UB9702-Q1 quad deserializer, providing connections for up to four external modules.
    The bandwidth estimates below use the public specifications of the DS90UB971-Q1 and DS90UB9702-Q1. Final component selection will depend on the selected sensors and the CQS290 interface capabilities.
    3. Whether the intermediate CSI-2 connection can reliably transport four independent camera streams using separate Virtual Channels.
    Yes. Four independent streams can share the intermediate CSI-2 connection using separate VC identifiers, provided their combined data rate fits within the available bandwidth.
    4. Whether the proposed architecture can support simultaneous transmission of all four camera streams.
    Yes. The SerDes architecture supports concurrent transport of all four streams by multiplexing their CSI-2 packets over the shared connection.
    The CQS290 must also support receiving, separating, and processing these streams. Please continue confirming its hardware and software capabilities with Cavli.
    5. If simultaneous transmission is not feasible, whether individual camera selection at the external deserializer would be a suitable alternative.
    Yes. If simultaneous capture is unavailable on the CQS290, forwarding one selected camera stream while keeping the cameras connected is a suitable alternative. The selected stream must still meet the host’s bandwidth and format requirements.
    6. The maximum aggregate bandwidth that could be supported through each stage.
    For the reference devices above, the maximum capacities are:
    Intermediate CSI-2 connection, from the external deserializer to the uplink serializer: 6 Gbps, using four lanes at 1.5 Gbps per lane.
    FPD-Link IV uplink, from the external module to the main PCB: 6 Gbps video payload capacity, at a 7.55 Gbps serial line rate.
    Central deserializer using one CSI-2 output: 10 Gbps, using four lanes at 2.5 Gbps per lane.
    Central deserializer using both CSI-2 outputs: 20 Gbps total.
    The initial four-camera configuration shares one 6 Gbps uplink. For sixteen cameras distributed across four external modules, the central deserializer’s 20 Gbps combined output capacity becomes the aggregate limit, assuming the CQS290 supports both interfaces at these rates.
    As an example, for uncompressed 8-bit YUV422 at 30 fps, with a preliminary 20% bandwidth reserve:
    Four cameras through one external module: approximately 2.50 megapixels per camera are available in the image-data budget. A common resolution target is 1920 × 1080 at 30 fps. Four such streams require approximately 3.98 Gbps of active-image bandwidth.
    Sixteen cameras using both central CSI-2 outputs: approximately 2.08 megapixels per camera are available. A common resolution target is 1920 × 1080 at 30 fps. Sixteen such streams require approximately 15.93 Gbps of active-image bandwidth.
    Sixteen cameras using one central CSI-2 output: approximately 1.04 megapixels per camera are available. A common resolution target is 1280 × 720 at 30 fps. Sixteen such streams require approximately 7.08 Gbps of active-image bandwidth.
    These are preliminary bandwidth targets, not guaranteed operating modes. They assume maximum interface rates and no additional FEC overhead. The 20% reserve is a planning assumption; actual CSI-2 timing, packet overhead, and host limitations must still be checked. In particular, sixteen-camera 1080p30 operation is close to this planning budget and requires further validation.
    7. Whether you recommend using one or both CSI-2 outputs of the central deserializer.
    For the initial four-camera configuration, one output can provide sufficient bandwidth when operated at an appropriate lane rate.
    For sixteen simultaneous cameras, both outputs are recommended. A balanced arrangement would carry eight camera streams on each output. Cavli would therefore need to confirm support for the corresponding VC count and simultaneous capture capacity on each input.
    Using both central outputs does not increase the 6 Gbps uplink capacity of an individual external module.
    8. Any additional hardware, synchronization or control requirements that should be considered.
    At the architecture level, the main considerations are CSI-2 interface compatibility, host support for the required VCs and simultaneous streams, camera control requirements, and whether the application requires synchronized frames.
    Concurrent transport does not itself guarantee synchronized image capture. Please specify any synchronization requirements before final sensor selection. Detailed implementation requirements can then be reviewed for the selected components.
    9. If additional camera parameters are required to perform a more accurate bandwidth and compatibility assessment, please let us know exactly which specifications you need us to provide.
    Please provide the following when available:
    Sensor models and intended resolution/frame-rate combinations.
    CSI-2 data formats and bit depths.
    CSI-2 lane counts, lane rates, and output timing.
    Any HDR exposures or embedded-data streams.
    Required number of simultaneous cameras and frame-synchronization requirements.
    Cavli’s confirmation of supported CSI-2 rates, VC handling, and simultaneous capture/processing limits.
    These details will allow us to refine the supported operating modes for both the initial four-camera system and the future sixteen-camera configuration.
    Yue
  • Hi Yue,
    Following your previous recommendations regarding the cascaded SerDes architecture, we would like to clarify two additional aspects concerning the hardware connections and control architecture.
    1. Electrical connections between the CQS290 and the main-board DS90UB9702-Q1
    The CQS290 exposes the following camera interface signals:
    MIPI CSI-2:
    • CSI0_CLK_N / CSI0_CLK_P
    • CSI0_LN0_N / CSI0_LN0_P
    • CSI0_LN1_N / CSI0_LN1_P
    • CSI0_LN2_N / CSI0_LN2_P
    • CSI0_LN3_N / CSI0_LN3_P
    I²C control:
    • CCI_I2C_SCL0
    • CCI_I2C_SDA0
    Additional camera signals:
    • CAM0_MCLK
    • CAM0_RST_N
    • CAM0_PWDN
    Our understanding is that the ten MIPI CSI-2 signals should connect directly to one of the CSI-2 TX output ports of the DS90UB9702-Q1 on the main PCB, using four data lanes and one clock lane.
    Similarly, CCI_I2C_SCL0 and CCI_I2C_SDA0 would connect to the I²C interface of the central deserializer, allowing the CQS290 to configure it.
    However, we are not sure how the three remaining signals should be connected.
    Based on the DS90UB9702-Q1 datasheet, we have identified the following pins:
    • REFCLK
    • PDB
    • RES
    We would appreciate your clarification on the following points:
    1. Could you provide the recommended connection scheme between the camera interface signals exposed by the CQS290 and the DS90UB9702-Q1?
    2. What is the intended function of CAM0_MCLK in this architecture? Should it be used to provide the reference clock to the external image sensors, or should the sensors have a separate local clock source? Is there any relationship between CAM0_MCLK and the DS90UB9702-Q1 REFCLK input?
    3. How should CAM0_RST_N and CAM0_PWDN be handled? Can they be used to control remote camera reset and power-down through the deserializer GPIOs, or do you recommend a different implementation?
    4. Should the DS90UB9702-Q1 PDB and RES signals be controlled independently by the main-board MCU or through another reset/power sequencing circuit?
    5. Are there any additional hardware connections required between the CQS290 and the central deserializer for camera control or synchronization?
    We would particularly appreciate a recommended connection diagram showing the complete interface between the CQS290 and the main-board DS90UB9702-Q1.
    2. Control architecture for the external module deserializer
    We would also like to discuss how to configure and control the DS90UB9702-Q1 located on the external camera module.
    Our proposed architecture includes an MCU on each board, with the following communication arrangement:
    External camera module:
    • The external DS90UB9702-Q1 is controlled directly by the external MCU through I²C.
    • The external MCU communicates with the main-board MCU through CAN.
    Main PCB:
    • The main-board MCU communicates with the CQS290 through USB.
    • The CQS290 receives the control information from the main-board MCU and configures the central DS90UB9702-Q1 directly through its CCI_I2C interface.
    The intended operation would therefore be:
    1. The CQS290 sends configuration commands to the main-board MCU through USB.
    2. The main-board MCU communicates the corresponding information to the external MCU through CAN.
    3. The external MCU configures the external DS90UB9702-Q1 through I²C.
    4. The central DS90UB9702-Q1 is configured directly by the CQS290 through its own I²C interface.
    We would like to know whether you consider this architecture technically suitable.
    Additionally, we would like to evaluate whether a simpler alternative is possible using the bidirectional control channel of FPD-Link IV.
    Specifically:
    1. Can the CQS290 access and configure the external DS90UB9702-Q1 through the I²C communication path of the central DS90UB9702-Q1 and the FPD-Link IV back channel?
    2. Considering that the external DS90UB9702-Q1 is connected to the CSI-2 input of the uplink DS90UB971-Q1, can the central deserializer communicate with it through this cascaded configuration?
    3. Can the same control path also provide access to the four camera serializers and their corresponding image sensors?
    4. If this remote I²C control architecture is supported, how should I²C addressing, aliasing and device access be configured to avoid address conflicts?
    5. Would you recommend this approach instead of using additional MCUs and a CAN communication link?
    Our objective is to understand the recommended control architecture before finalizing the hardware design of both PCBs.
    Juan
  • Hi Juan,
    Please see our answers below, following the order of your questions.
    One system-level point remains unresolved: you previously indicated that the CQS290 SDK does not support CSI-2 VC demultiplexing. Please confirm whether the intended operation remains one selected camera stream per physical CSI-2 interface. Simultaneous independent capture of multiple VC streams through the same interface cannot be supported with that SDK limitation.
    1.1 Could you provide the recommended connection scheme?
    Yes. For a four-lane D-PHY connection using the DS90UB9702-Q1 CSI0 output, the following interface arrangement can be used. Connect N to N and P to P.
    CQS290 Main-board DS90UB9702-Q1
    CSI0_CLK_N/P <------------ CSI0_CLK0N/P (pins 31/32)
    CSI0_LN0_N/P <------------ CSI0_D0N/P (pins 33/34)
    CSI0_LN1_N/P <------------ CSI0_D1N/P (pins 35/36)
    CSI0_LN2_N/P <------------ CSI0_D2N/P (pins 39/40)
    CSI0_LN3_N/P <------------ CSI0_D3N/P (pins 41/42)
    CCI_I2C_SCL0 <-----------> I2C_SCL (pin 68)
    CCI_I2C_SDA0 <-----------> I2C_SDA (pin 67)
    CAM0_RST_N -- optional -> GPIO input for remote routing
    CAM0_PWDN -- optional -> GPIO input for remote routing
    Selected GPIO,
    MCU or sequencer -----------> PDB (pin 61)
    Host IRQ input <------------ INTB (pin 9, optional)
    Separate 25-MHz oscillator --> REFCLK (pin 15)
    RES (pin 60) -- 10 kΩ -- GND
    CAM0_MCLK: not connected in this example.
    Common ground is required.
    CSI0_CLK1N/P is unused in this four-lane configuration. The CSI-2 connection is DC-coupled; FPD-Link-style AC-coupling capacitors are not required. Configure the lane rate, clock mode, data type and VC assignment to match the CQS290 receiver.
    The I²C pull-ups must match the CQS290 interface voltage and the selected deserializer VDDIO supply. The diagram covers the interface connections; the complete power, decoupling, strap and supporting circuitry remains required.
    1.2 What is the function of CAM0_MCLK, and how does it relate to REFCLK and the remote sensor clocks?
    CAM0_MCLK is optional in this arrangement; it is not automatically a suitable REFCLK source.
    The DS90UB9702-Q1 requires a 25-MHz LVCMOS reference clock with ±100-ppm frequency accuracy, meeting its electrical and jitter requirements. CAM0_MCLK could supply REFCLK only if it meets these specifications and is available throughout initialization and operation. A clock enabled only during camera streaming should not be assumed suitable.
    The example therefore uses a separate reference oscillator. Remote sensors can use the camera serializer’s CLKOUT or a local oscillator, depending on the selected operating mode and sensor requirements. Each stage needs a defined clocking arrangement.
    1.3 Can CAM0_RST_N and CAM0_PWDN control remote cameras through deserializer GPIOs?
    Yes, with the required GPIO connections and configuration at each stage.
    For your cascade, the intended path would be:
    CQS290 GPIO
    → Central deserializer GPIO input
    → Uplink serializer GPIO output
    → External HUB GPIO input
    → Camera serializer GPIO output
    → Sensor reset/power-down input
    The intermediate GPIO connection must be physically implemented. These signals do not propagate automatically through CSI-2.
    Alternatively, software can control remote GPIO output levels through I²C. Independent control of multiple cameras requires per-camera routing or addressed control.
    GPIO forwarding depends on link establishment and configuration, so local circuitry must provide suitable startup states, polarity and timing.
    1.4 Should PDB and RES be controlled independently by the MCU or a sequencing circuit?
    Only PDB requires an enable/reset control arrangement. RES must not be driven as a reset signal.
    PDB may be controlled by a CQS290 GPIO, MCU or sequencing circuit. A separate MCU is not mandatory, but its bias network and power-up timing must follow the datasheet.
    RES, pin 60, connects to ground through a 10-kΩ resistor. It is not a reset input.
    Keep central-deserializer control separate from individual camera reset operations unless the software intentionally manages a complete HUB restart.
    1.5 Are additional hardware connections needed for control or synchronization?
    Additional connections depend on the required monitoring and synchronization functions.
    INTB can provide interrupt notification, and LOCK can provide hardware link-status indication. These are optional; status can also be read through I²C.
    If synchronized capture is required, define a frame-sync source and route it through the necessary stages to the sensors’ synchronization inputs.
    CAM0_MCLK is not a frame-sync signal. The complete cascade requires explicit consideration of synchronization routing, delay and skew.
    2. Control architecture for the external-module deserializer
    Your proposed MCU/CAN architecture is technically reasonable. Each external MCU can configure its local deserializer, while the CQS290 configures the central deserializer.
    Your software must implement the USB/CAN command protocol, completion reporting, error handling and startup sequence. Assign a clear configuration owner to each device. This arrangement also allows local recovery through CAN when FPD-Link is unavailable.
    2.1 Can the CQS290 configure the external DS90UB9702-Q1 through the central deserializer and FPD-Link control channel?
    Yes, provided the external deserializer is connected to the uplink serializer’s I²C bus.
    The external DS90UB9702-Q1 can then be accessed as a remote I²C target:
    CQS290 → Central 9702 → FPD-Link → Uplink 971
        │ I²C
        External 9702
    This requires compatible I²C voltage levels, address mapping and control-channel configuration. The CQS290 controller and driver must also support clock stretching.
    2.2 Does the CSI-2 connection between the external deserializer and uplink serializer establish this control path?
    No. A separate SCL/SDA connection is required.
    The CSI-2 connection carries video from the external deserializer to the uplink serializer. To configure the external deserializer remotely, connect its I²C interface to the uplink serializer’s I²C interface as shown above.
    2.3 Can the same control path access the four camera serializers and their sensors?
    Yes, provided that both stages have the required I²C connections, forwarding configuration and address mappings.
    The uplink serializer must connect to the external HUB through I²C. The external HUB then forwards transactions to the camera serializers and sensors through its own FPD-Link connections.
    Clock-stretching support and timeout settings must be checked along the complete control path, including the CQS290 CCI controller and driver.
    2.4 How should addressing and aliasing be configured to avoid conflicts?
    Use address translation at both deserializers, with unique host-visible aliases for devices requiring individual access.
    The central deserializer maps a host-visible alias to an address recognized on the external module’s I²C bus. The external HUB then maps that address to the camera serializer or sensor on the selected camera link.
    Consequently, the central deserializer’s Target ID may contain an alias configured in the external HUB rather than the final sensor’s physical address.
    Configure the serializer ID/alias through 0x5B/0x5C and enable I²C pass-through through 0x58[6]. Additional Target ID/Alias mappings are required for the external HUB and downstream camera devices.
    Each RX port has eight Target ID/Alias pairs, so mapping resources must be planned and may be reconfigured as needed. Also confirm whether the CQS290 I²C API expects 7-bit or 8-bit address notation before transferring register examples into your software.
    2.5 Would you recommend this approach instead of additional MCUs and CAN?
    Yes, if the additional MCUs and CAN link are intended only to relay SerDes and sensor register-configuration commands, centralized remote I²C can replace that function.
    However, removing the MCUs depends on their other responsibilities. If they also provide power sequencing, independent monitoring or recovery when FPD-Link is unavailable, those functions still require an implementation.
    The choice should therefore be based on the system’s startup, monitoring and fault-recovery requirements.
    We should also confirm the CQS290 VC-support and simultaneous-capture requirements before finalizing the hardware.
    Yue Lei
  • Hi Yue,
    Thank you for your detailed explanations. We would like to clarify a few additional points before finalizing our hardware architecture.
    1. Compatibility of the proposed architecture with both camera operating modes
    Regardless of the CSI-2 Virtual Channel limitations that we are still waiting for Cavli to confirm, could you please clarify whether the proposed hardware architecture based on the DS90UB9702-Q1 and DS90UB971-Q1 would be suitable for both of the following operating scenarios?
    1. Simultaneous camera streaming: All four cameras connected to the external module transmit their video streams simultaneously, using separate CSI-2 Virtual Channels.
    2. Individual camera selection: All four cameras remain physically connected to the external module, but only one camera is selected and forwarded to the CQS290 at a time.
    In other words, we would like to confirm that the proposed SerDes architecture does not need to be modified depending on which of these two operating modes is eventually supported by the CQS290.
    2. Required connections between the external module and the main PCB
    We would also like to verify that we have correctly understood the physical connections required between the external camera module and the main PCB.
    Based on your previous explanation, our understanding is as follows:
    • FPD-Link IV connection: Only the RIN0+ and RIN0− inputs of the central DS90UB9702-Q1 on the main PCB need to be connected to the corresponding FPD-Link output of the uplink DS90UB971-Q1 located on the external module.
    • External module I²C connection: The I²C interface of the uplink DS90UB971-Q1 must be physically connected to the I²C interface of the external DS90UB9702-Q1.
    • External module CSI-2 connection: The CSI-2 output of the external DS90UB9702-Q1 must be connected to the CSI-2 input of the uplink DS90UB971-Q1.
    • Camera connections: The external DS90UB9702-Q1 connects to the four camera DS90UB971-Q1 serializers through their respective FPD-Link connections. Each serializer is then connected to its corresponding image sensor.
    Could you please confirm whether this is the complete set of connections required between the external module and the main PCB?
    More specifically, is the single FPD-Link IV connection between the central deserializer and the uplink serializer sufficient to carry both the video data towards the main PCB and the I²C control traffic in the reverse direction, or is any additional physical connection required between the two boards?
    We would like to identify all the necessary interconnections before defining the external module connector and PCB layout.
    3. DS90UB9702-Q1 datasheet and power supply requirements
    I have requested the complete DS90UB9702-Q1 datasheet through the link provided on your website, but I have not received it yet. Could you please send us the complete datasheet directly?
    There is also an important power supply requirement that we need to clarify.
    We have reviewed the DS90UB960-Q1 datasheet, and its required supply rails include:
    • 1.1 V core supply. (VDD_FPD1,VDD_FPD2)
    • 1.8 V supply. (VDD18_P2,VDD18_P3,VDD18_P1,VDD18_P0, VDD18A, VDD18_FPD0, VDD18_FPD1, VDD18_FPD2, VDD18_FPD3)
    • VDDIO: 1.8 V or 3.3 V.
    However, for our design, we need a deserializer with the following power supply requirements:
    • 1.2 V core supply.
    • 3.3 V main supply.
    Could you please confirm the exact power supply requirements of the DS90UB9702-Q1 and whether it meets these requirements?
    If it does not, could you recommend an alternative deserializer compatible with the proposed FPD-Link IV architecture that meets these supply voltage requirements?
    Juan
  • Hi Juan,
    Please find our responses below, following your questions individually.
    1. Compatibility with both camera operating modes
    1.1 Can all four cameras stream simultaneously using separate Virtual Channels?
    Yes, provided the combined traffic fits within the available bandwidth. The external DS90UB9702-Q1 can aggregate the four camera streams onto one CSI-2 output with distinct VC IDs. The uplink DS90UB971-Q1 then transports this aggregated stream to the central deserializer.
    The uplink DS90UB971-Q1 supports up to 1.5 Gbps per CSI-2 data lane, or 6 Gbps across four lanes. Its 7.55-Gbps FPD-Link line rate provides approximately 6 Gbps of video payload capacity. The bandwidth assessment must account for packet overhead and transmission timing, in addition to the active-pixel data.
    Simultaneous capture by the CQS290 remains subject to Cavli confirming its multi-VC support.
    1.2 Can all four cameras remain connected while only one is selected and forwarded?
    Yes. The external deserializer can enable forwarding for the selected camera and disable forwarding for the others, without changing their physical connections.
    For a receiver expecting one fixed VC, the selected stream can be mapped to a consistent VC ID. The receiver software must also handle any stream interruption or format change during camera switching.
    1.3 Can the same hardware support both modes without modification?
    Yes, provided the hardware is designed for simultaneous operation from the outset. The operating mode can then be changed through forwarding and VC configuration.
    In particular, the external deserializer’s CSI-2 output connected to the uplink serializer must operate within the DS90UB971-Q1 input limits. It must not use a 2.5-Gbps/lane setting on this connection.
    This confirmation applies per external module. If multiple modules stream simultaneously, the central deserializer’s CSI-2 output bandwidth and the CQS290’s reception capability must also accommodate their combined traffic.
    2. Connections between the external module and the main PCB
    2.1 Is one central deserializer RX port sufficient to connect the uplink serializer?
    Yes. Each external module’s uplink serializer requires one FPD-Link connection to one RX port of the central deserializer. RX0 is one possible choice; additional external modules would use additional RX ports.
    Please distinguish the cable configurations:
    Coax: DOUT+ and RIN0+ carry the signal through the recommended AC-coupling network. DOUT− and RIN0− are separately terminated to ground using the recommended capacitor/resistor networks.
    STP: Both positive and negative signal paths are connected through their AC-coupling networks.
    Therefore, RIN0+ and RIN0− should not both be treated as cable signal connections when using coax.
    2.2 Must the uplink serializer’s I²C interface physically connect to the external deserializer?
    Yes, if remote access to the external deserializer is required. Connect the uplink serializer’s SDA/SCL to the external deserializer’s I²C interface, with compatible voltage levels and pull-ups.
    I²C forwarding and address mappings must be configured at both stages. The CSI-2 connection alone does not provide this control path.
    2.3 Should the external deserializer’s CSI-2 output connect to the uplink serializer’s CSI-2 input?
    Yes. Match the data-lane connections, lane count, lane rate and continuous/non-continuous clock configuration between the two devices.
    2.4 Are the proposed camera connections correct?
    Yes. Each camera serializer connects to a separate FPD-Link RX port of the external deserializer, and each image sensor connects to its corresponding serializer’s CSI-2 input.
    2.5 Can the single inter-board FPD-Link connection carry both video and I²C control?
    Yes. The same connection carries forward video and bidirectional control traffic. Separate inter-board I²C or CSI-2 wiring is not required for these functions.
    Access to the external hub and downstream camera devices requires the appropriate forwarding, aliasing and controller timing configuration.
    2.6 Does this cover all required inter-board connections?
    It covers the video and remote-control connections. The connector design must also address power and ground/shielding.
    The external module may have an independent power supply or receive power through PoC, with the corresponding circuitry at both ends. Each board still requires its local supplies, reference clocks, startup configuration and power-up/reset circuitry. These must establish the basic operating conditions before remote control becomes available.
    3. Complete datasheet and power supplies
    3.1 Can the complete DS90UB9702-Q1 datasheet be provided directly here?
    No. Please note that this is a public thread, and we cannot provide the complete datasheet directly here. Please contact your local TI representative or FAE, or follow the official access-request process on the DS90UB9702-Q1 product page.
    3.2 What are the exact supply requirements of the DS90UB9702-Q1?
    The required supply voltages are:
    VDD11: 1.1 V nominal, with a recommended operating range of 1.045–1.155 V.
    VDD18: 1.8 V nominal, with a recommended operating range of 1.71–1.89 V.
    VDDIO: either 1.8 V within 1.71–1.89 V, or 3.3 V within 3.0–3.6 V.
    The supply filtering, decoupling and power-up sequence must also follow the device requirements.
    3.3 Does it support a 1.2-V core supply and a 3.3-V main supply?
    No, these voltages cannot directly replace the required device supplies. A 1.2-V supply exceeds the recommended VDD11 operating range, and 3.3 V cannot replace VDD18. Support for 3.3-V VDDIO does not mean that the device supports a 3.3-V main supply.
    3.4 Is there a compatible alternative meeting this supply combination?
    No. For the proposed automotive FPD-Link IV camera architecture, we do not have a compatible deserializer that directly supports the specified 1.2-V core and 3.3-V main-supply combination.
    If these are the rails currently available on your board, suitable regulators can generate the required 1.1-V and 1.8-V supplies. This would allow you to retain the proposed SerDes topology.
    Yue
  • Hi Yue,
    Thank you for the clarification regarding the coaxial and STP configurations.
    We would like to explore two additional aspects before making a final decision on the SerDes technology and the interconnection between the main PCB and the external camera modules.
    1. Coaxial vs. STP – Technical comparison
    Could you please provide a more detailed comparison between coaxial and STP cabling when used with the DS90UB9702-Q1 and DS90UB971-Q1?
    In particular, we would like to understand the main advantages and disadvantages of each option in terms of:
    • Signal integrity and transmission performance.
    • Maximum achievable cable length and supported data rates.
    • Electromagnetic compatibility (EMC) and immunity to external interference.
    • Susceptibility to noise and common-mode interference.
    • Cable flexibility, diameter, weight and installation constraints.
    • Connector availability, cost and ease of integration.
    • Suitability for automotive and harsh-environment applications.
    Our application involves connecting external camera modules to the main PCB inside a vehicle. We would therefore appreciate your recommendation regarding which configuration would be more suitable for this type of installation.
    2. Power supply requirements – FPD-Link IV vs. FPD-Link III
    As mentioned previously, one of our main concerns with the DS90UB9702-Q1 is its power supply requirements.
    Our target power supply architecture is based on:
    • 1.8 V or 3.3 V I/O supply.
    However, the DS90UB9702-Q1 requires separate 1.1 V and 1.8 V supplies, in addition to VDDIO. This introduces additional voltage regulation stages that we would prefer to avoid if possible.
    We have therefore started evaluating FPD-Link III alternatives and came across the DS90UB940N-Q1, whose supply requirements appear to be more compatible with our available voltage rails.
    Could you please clarify the following points?
    1. Would the DS90UB940N-Q1 be suitable for our proposed architecture, considering that we need to aggregate up to four camera streams in the external module and transmit them to the main PCB through an uplink SerDes?
    2. Could an FPD-Link III architecture support the same functionality we have discussed for FPD-Link IV, including simultaneous transmission of multiple camera streams using Virtual Channels and individual camera selection?
    3. Are there any significant limitations in terms of bandwidth, CSI-2 lane rates, number of supported cameras or bidirectional I²C control that we should consider when comparing FPD-Link III with FPD-Link IV?
    4. If the DS90UB940N-Q1 is not suitable, could you recommend another FPD-Link III or FPD-Link IV deserializer/serializer combination that better matches our power supply requirements?
    Our objective is to retain the proposed architecture, with four camera serializers connected to an external deserializer, followed by an uplink serializer transmitting the aggregated video to a central deserializer on the main PCB.
    We would appreciate your recommendation on the most suitable SerDes family and device combination for this application, taking into account both the functional requirements and the power supply constraints.
    Thank you for your continued support.
    Juan
  • 3. CQS290 MIPI CSI-2 interface specifications
    To help you evaluate the compatibility of the proposed architecture with the CQS290, we would also like to share the MIPI CSI-2 specifications confirmed by Cavli.
    The CQS290 provides two independent MIPI CSI-2 interfaces, with the following maximum capabilities:
    • Maximum data rate: 2.5 Gbps per lane.
    • Maximum number of lanes: 4 per interface.
    • Maximum bandwidth: 10 Gbps per interface.
    Regarding camera resolution and operating modes, Cavli has clarified the following:
    Operating mode Maximum resolution / frame rate
    Video recording 1080p30
    Video recording 720p30
    Video recording 480p120 (HFR requires a feature request)
    Snapshot 21 MP at 30 fps
    • RAW8
    • RAW10
    • RAW12
    • NV12
    • NV21
    • JPEG
    Please note that Cavli has clarified that the 21 MP maximum resolution applies to snapshot use cases only, not continuous video recording.
    Considering these specifications, could you please confirm:
    1. Whether the proposed FPD-Link IV or III architecture can deliver the aggregated video stream from four cameras to one CQS290 CSI-2 interface within the available bandwidth.
    2. Whether the same architecture could support the four cameras distributed across the CQS290's two independent CSI-2 interfaces, if required.
    3. Whether the proposed architecture and the DS90UB940N-Q1 or any alternative FPD-Link III solution would be compatible with these CSI-2 lane rates, lane counts and supported pixel formats.
    4. Whether there are any additional limitations on CSI-2 data types, Virtual Channel handling or simultaneous camera streams that we should consider.
    Ideally, we would like to support both operating modes:
    • Simultaneous transmission of all four camera streams using separate Virtual Channels. (We are awaiting confirmation from Cavli)
    • Individual selection of one camera at a time, while keeping all four cameras physically connected.
    We would appreciate your recommendation on the most suitable SerDes family and device combination for this application, taking into account the video requirements, power supply constraints and automotive environment.
    Juan
  • Hi Juan,
    Thank you for sharing the detailed CQS290 specifications. This information helps us assess the physical interface and transmission bandwidth compatibility. Please find our responses below.
    1. Delivering four aggregated streams to one CQS290 CSI-2 interface
    The FPD-Link IV solution has sufficient bandwidth potential, subject to confirming the cameras’ actual output formats and timing.
    In the proposed architecture, the uplink DS90UB971-Q1 supports four CSI-2 data lanes at up to 1.5 Gbps per lane, giving 6 Gbps in total. Its FPD-Link video payload capacity is approximately 6 Gbps. This uplink must accommodate the combined traffic from all four cameras.
    For four 1080p30 streams, the active-pixel data alone requires approximately:
    RAW8: 1.99 Gbps.
    RAW10: 2.49 Gbps.
    RAW12: 2.99 Gbps.
    YUV422 at 16 bits/pixel: 3.98 Gbps.
    These figures support continuing the evaluation of the FPD-Link IV architecture. Packet overhead, embedded data and actual transmission timing must also be included. The calculation should use the cameras’ CSI-2 output traffic, rather than the compressed recording bitrate.
    The CQS290’s 10-Gbps interface capability provides receiving bandwidth, but simultaneous capture still depends on Cavli confirming multi-VC support and the required processing capability.
    2. Distributing the four cameras across two CQS290 CSI-2 interfaces
    With the current single-uplink topology, the central DS90UB9702-Q1 cannot directly split four VCs arriving through one RX port into two groups assigned to separate CSI-2 outputs.
    The DS90UB9702-Q1 routes video to its CSI-2 outputs at RX-port granularity. After aggregation and transmission through the uplink serializer, all four streams enter the same central RX port. VC remapping changes the channel identifiers; it does not provide this two-plus-two output routing.
    One direct implementation would use both CSI-2 outputs of the external deserializer, each connected to a separate uplink serializer. Two FPD-Link connections would then feed two RX ports of the central deserializer, which could be assigned to separate CSI-2 outputs. This would require changes to the uplink hardware.
    Another option to discuss is replicating the complete aggregated stream onto both CSI-2 outputs and having each CQS290 receiver select the required VCs. This requires Cavli to confirm receiver-side VC filtering, and each CSI-2 interface must accommodate the complete aggregated stream.
    In either case, receiving two independent streams simultaneously on each interface still requires the corresponding multi-VC capture support.
    3. DS90UB940N-Q1 and alternative FPD-Link III solutions
    The DS90UB940N-Q1 is not a direct replacement for the proposed DS90UB971-Q1 camera link.
    The DS90UB940N-Q1 pairs with serializers such as the DS90UB949-Q1, DS90UB947-Q1 and DS90UB929-Q1. Although its 1.2-V and 3.3-V supplies match your previously stated voltage requirements, it is not compatible with the proposed DS90UB971-Q1 cascaded camera link.
    For an FPD-Link III camera solution, compatible combinations such as DS90UB953-Q1 and DS90UB960-Q1 can be evaluated, but the aggregated uplink bandwidth must be recalculated. For example, one DS90UB953-Q1 supports up to approximately 3.328 Gbps across its four CSI-2 input lanes. Four 1080p30 YUV422 streams exceed this limit even before packet overhead is included. Therefore, FPD-Link III is not an equivalent replacement under all the formats and operating conditions discussed.
    Also, the CQS290’s maximum lane rate of 2.5 Gbps does not require the deserializer to transmit at that rate. A lower rate supported by both devices can be used, subject to Cavli confirming the corresponding driver configuration.
    4. Pixel formats, Virtual Channels and simultaneous operation
    RAW8, RAW10 and RAW12 can be transported through the proposed camera SerDes link. The receiver must still be configured for the actual data types, VCs and image-processing requirements.
    The meaning of NV12, NV21 and JPEG in Cavli’s list needs clarification:
    NV12/NV21 normally describe YUV memory layouts. Please confirm whether the list refers to CSI-2 input formats or formats produced after ISP processing.
    Support for generating JPEG snapshots does not necessarily mean that the CSI-2 input accepts externally generated JPEG data. The SerDes devices do not perform JPEG encoding, decoding or RAW-to-YUV conversion.
    Similarly, support for single-stream 1080p30 recording does not establish support for capturing and recording four 1080p30 streams simultaneously. In addition to multi-VC support, Cavli needs to confirm the corresponding capture, ISP and encoding capabilities. The 21-MP snapshot specification should not be used to infer continuous multi-camera recording capability.
    5. Architecture and device-selection direction
    Based on the information available, we recommend retaining DS90UB971-Q1 and DS90UB9702-Q1 as the evaluation baseline for the FPD-Link IV cascade. These are automotive-qualified devices, and their transmission capacity provides more room for four-camera aggregation.
    Individual camera selection can be implemented through forwarding control in the external deserializer while keeping all four cameras connected. Simultaneous forwarding can use the same hardware if it is designed for four-camera operation, but simultaneous capture remains subject to Cavli’s confirmation.
    For power, the DS90UB9702-Q1 still requires 1.1 V and 1.8 V, with VDDIO selectable as 1.8 V or 3.3 V. If only 1.2-V and 3.3-V rails are available, additional regulation is required. The DS90UB940N-Q1 cannot be used to avoid this supply requirement while retaining the proposed link.
    Once Cavli clarifies multi-VC support, simultaneous processing capability and whether the format list describes CSI-2 inputs or processed outputs, we can further narrow down the final device combination and configuration.
    Yue
  • Hi Yue,
    Thank you for your detailed feedback and recommendations.
    While we are waiting for Cavli to clarify the remaining questions regarding the CQS290's multi-VC support, simultaneous camera capture and image format requirements, we would like to follow up on one point from our previous email that has not yet been addressed.
    Could you please provide the detailed comparison between coaxial and STP cabling when used with the DS90UB9702-Q1 and DS90UB971-Q1?
    We need to select the most suitable physical connection between the main PCB and the external camera module for our automotive application.
    In particular, we would appreciate your feedback on the following aspects:
    • Signal integrity and transmission performance: Are there significant differences in signal quality or robustness between the two configurations?
    • Maximum cable length and data rate: Do both configurations support the same maximum data rates and transmission distances?
    • EMC performance: Which configuration provides better electromagnetic compatibility and immunity to external interference?
    • Noise immunity: Are there differences in susceptibility to common-mode noise and electromagnetic disturbances?
    • Mechanical characteristics: How do they compare in terms of cable diameter, flexibility, weight and installation constraints?
    • Connectors and cost: Which option offers better connector availability, lower cost and easier PCB integration?
    • Automotive suitability: Which configuration would you recommend for an installation inside a vehicle, considering vibration, temperature variations and harsh electromagnetic environments?
    In addition, could you clarify whether there are any specific design recommendations or limitations regarding cable shielding, grounding and connector implementation for each configuration?
    Our objective is to choose the most reliable and practical solution for connecting the external camera module to the main PCB.
    We would appreciate your recommendation on whether to use coaxial or STP for our particular application.
    Thank you again for your support.
    Juan
  • Regarding the power supply requirements, we would like to emphasise that this is a particularly important point for our design. We are insisting on this matter because we cannot accommodate any additional power management or voltage conversion circuitry on our PCB.
    Therefore, we would like to know whether there is an alternative solution or configuration that allows the device to operate with a main supply voltage of 1.2 V, 3.3 V, or 1.8 V for VDDIO.
    We would appreciate it if you could recommend a suitable solution for our application with those supply voltage.
    Juan
  • Hi Juan,
    Both coaxial and STP connections are supported by the DS90UB971-Q1 and DS90UB9702-Q1. For your application, we suggest evaluating automotive-grade 50 Ω coax first, provided the complete channel meets TI’s requirements.
    The main limitation remains the power supply. The DS90UB9702-Q1 requires 1.1 V and 1.8 V, with VDDIO selectable between 1.8 V and 3.3 V. A 1.2 V supply cannot replace the required 1.1 V rail, and no register configuration removes this requirement.
    Some FPD-Link III devices support your specified supply voltages, but they do not meet the requirements of the proposed cascaded architecture and cannot directly replace the DS90UB9702-Q1.
    If a compliant 1.1 V supply cannot be provided, the power arrangement or SerDes architecture will need to be revised.
    Yue
  • Hi Yue,
    Thank you for your feedback and for clarifying the power supply requirements of the DS90UB9702-Q1.
    We would like to follow up on two points to better understand the available options and determine the most suitable architecture for our application.
    In your previous response, you recommended evaluating automotive-grade 50 Ω coaxial cabling first, provided that the complete channel meets TI's requirements.
    However, we would still appreciate receiving the detailed technical comparison between coaxial and STP cabling.
    Additionally, could you clarify whether there are any specific design recommendations or limitations regarding cable shielding, grounding and connector implementation for each configuration?
    We would therefore appreciate your recommendation on whether coaxial or STP would be more suitable for our particular application.
    2. Alternative architecture using FPD-Link III throughout the complete camera system
    Regarding the power supply limitation, we would like to clarify our question about the possible use of FPD-Link III devices.
    Our intention is not to replace only the deserializer on the main PCB with an FPD-Link III device while keeping an FPD-Link IV serializer/deserializer pair in the external camera module.
    Instead, we would like to know whether it is possible to implement the entire SerDes architecture using FPD-Link III devices, as follows:
    • Main PCB: An FPD-Link III deserializer.
    • External camera module: An FPD-Link III serializer connected to the camera sensor, together with an FPD-Link III deserializer.
    • Communication: The complete architecture would maintain the remote I2C control functionality, allowing the main processor to configure and control the external camera sensor through the SerDes link.
    In other words, we would like to understand whether an architecture in which all SerDes links are FPD-Link III, including the cascaded connection between the external camera module and the main PCB, could meet our application requirements.
    We understand that FPD-Link III devices may not offer exactly the same capabilities as FPD-Link IV. Nevertheless, we would like to evaluate whether a complete FPD-Link III solution could provide a technically viable alternative while preserving the required system architecture and remote camera control.
    Thank you in advance for your clarification and technical recommendations.
    Juan
  • Hello Juan,
    We are a SER/DES manufacturer not a cable manufacturer. For answering these questions and doing the detailed comparison, I would recommend you to contact your cable vendor, such as Leoni-Dacar.
    This depends completely on your datarate. If that is within the FPD-Link III capability, then yes sure you can use FPD-Link III SER/DES for your link.
    Thank you for your feedback.
    We would like to clarify a few points and provide additional information about our proposed architecture to help us identify the most suitable SerDes devices.
    1. Coaxial vs. STP – Clarification
      We understand that TI is a SerDes manufacturer rather than a cable manufacturer.
      Our intention was not to request a detailed cable comparison or a cable qualification study. We simply wanted to ask about the connection types supported by your SerDes devices, as both coaxial and STP are mentioned in their documentation.
      Since you have extensive experience with these devices, we would appreciate any recommendations or information regarding potential limitations, particularly concerning the maximum supported cable length for each connection type.
    2. Proposed architecture
      Based on the information provided in this ticket and the answers received so far, we would like to share a diagram of our proposed architecture (attached) to clarify our requirements and help us select the appropriate devices.
      An important point is that the power supply limitation only applies to the main PCB. The external camera module does not have this limitation, and we can provide any power supply voltages required by the selected devices.
      A. External camera module
      We intend to connect four cameras, each with its own serializer, to a four-channel deserializer. The output of this deserializer (MIPI CSI-2) would then be connected to an additional serializer (uplink serializer), which transmits the aggregated camera data to the main PCB.
      Since there are no power supply restrictions in the external module, we can use any suitable SerDes devices.
      For an FPD-Link III implementation, we have identified some potential four-channel deserializers, such as:
      • DS90UB960-Q1.
      • DS90UB964-Q1.
      • DS90UB962-Q1.
      B. Main PCB
      The main PCB has strict power supply constraints. We need to use devices compatible with our available voltage rails: 1.2 V, 1.8 V or 3.3 V.
      For an FPD-Link III implementation, we have identified the following potential deserializers:
      • DS90UB940N-Q1.
      • DS90UB940-Q1.
      Since the communication between the uplink serializer in the external module and the deserializer on the main PCB only requires one SerDes connection, we believe that using a single input port (RIN0+/RIN0-) on the main PCB deserializer should be sufficient.
      Therefore, even if the selected deserializer provides multiple input ports, we would only need to use one of them.
      Could you please confirm whether this architecture is technically feasible and recommend the appropriate serializer/deserializer combination for each section?
    3. FPD-Link IV alternatives
      We would also like to evaluate the possibility of implementing the same architecture using FPD-Link IV.
      However, we currently do not have access to the datasheets of all your FPD-Link IV devices, so we cannot determine whether there are deserializers compatible with our main PCB power supply requirements (1.2 V, 1.8 V or 3.3 V).
      Could you please let us know whether any FPD-Link IV deserializers meet these power supply requirements?
      Even if these devices only provide one or two input ports, that would not be a problem for the main PCB, since we only need one SerDes input connection there.
      As mentioned previously, the external camera module has no power supply restrictions, so any suitable FPD-Link IV device could be considered for that section.
    4. Camera specifications and bandwidth requirements
      To help you assess the required bandwidth and determine whether FPD-Link III or FPD-Link IV would be more appropriate, we can provide some preliminary camera specifications that would be suitable for our application:
      • Resolution: 4 MP.
      • Frame rate: 15 fps.
      • Maximum data rate: 2048 Mbps.
      These specifications are sufficient for our application, and we are not necessarily limited to the camera supplied with the development kit.
    5. Remote I2C control across the proposed SerDes architecture
      As previously discussed, we understand that your SerDes devices support bidirectional I2C communication, allowing the MPU on the main PCB to remotely configure and access devices located in the external camera module.
      We would like to confirm whether this functionality can also be maintained with the specific combination of serializers and deserializers proposed in our architecture, considering that we may use different SerDes devices at each stage.
      Specifically, we would like to confirm whether the MPU can communicate through I2C with the four camera sensors, their respective serializers and the deserializer located in the external module, through the following chain:
      MPU → Main PCB Deserializer → External Module Uplink Serializer → External Module Deserializer → Camera Serializers → Image Sensors.
      Is bidirectional I2C communication supported across this complete architecture, including all the cascaded SerDes links and the different device combinations proposed?
      If there are any compatibility restrictions or specific configuration requirements, we would appreciate your clarification.
      As an alternative, if this particular combination of SerDes devices does not support remote I2C communication across the complete chain, we could implement a dedicated MCU on the external camera module, communicating with the MCU on the main PCB.
    Our objective is to select the most appropriate automotive-grade SerDes devices for both PCBs while maintaining the proposed four-camera architecture and meeting the power supply constraints of the main PCB.
    Thank you for your support. We look forward to your technical recommendations.
    Juan
  • Hello Juan,
    Weather you use Coax or STP is completely up to the need of you design. Coax are mainly more fixable and lower cost than STP. Also using coax you can utilize PoC but not possible using STP. Mainly ADAS customers use Coax.
    • DS90UB960-Q1.
    • DS90UB964-Q1.
    • DS90UB962-Q1.
    I recommend you use the UB960.
    The architecture is technically feasible but not sure what UpLink SER are you planning to use?
    What is the intended CSI throughput you are planning to transmit into the Uplink SER and then to the Main PCB DES?
    All our Quad DES require 1.1V and 1.8V. 3.3V is optional for IO/I2C.
    The Dual input DES, the DS90UB954 requires just a single power supply, 1.8V. Which you may use on your Main PCB due to power restrictions.
    • Resolution: 4 MP.
    That is useful, but I need the data type coming out of the image sensor. Is this RAW10, 12, YUV422 8-bit, 10-bit ...etc? please specify.
    Also, if you know the blanking needed by your image sensor will be very helpful to calculate the right numbers.
    Yes, bidirectional I2C communication is supported in the above architecture.
  • Hello Hamzeh,
    Thank you very much for the information and recommendations provided.
    Based on your feedback, we would like to clarify a few additional points regarding the selection of the SerDes devices for our proposed architecture.
    1. External camera module – Deserializer selection
    Understood. We will consider the DS90UB960-Q1 as the four-channel deserializer for the external camera module, where the four cameras will each be connected to their respective serializers.
    2. Main PCB – Deserializer selection
    Regarding the deserializer on the main PCB, considering our power supply constraints, which of the following devices would you recommend?
    • DS90UB940N-Q1.
    • DS90UB940-Q1.
    We would appreciate your recommendation regarding which device would be more suitable for receiving the video stream from the uplink serializer located in the external camera module.
    3. Serializer selection
    Regarding the serializers, we understand that we need two different groups of serializers in our architecture:
    • Camera serializers (4 units): One serializer per camera, connecting each image sensor to the four-channel DS90UB960-Q1 deserializer located in the external module.
    • Uplink serializer (1 unit): An additional serializer connected to the MIPI CSI-2 output of the DS90UB960-Q1. This serializer will transmit the aggregated video streams to the deserializer located on the main PCB.
    We would appreciate your recommendation regarding the most suitable serializer devices for both stages, ensuring compatibility with the selected deserializers.
    4. Image sensor data format
    We have not selected the specific image sensor yet.
    However, our understanding is that the sensor output format must be compatible with both the selected SerDes devices and the MIPI CSI-2 interface of our MPU.
    According to the specifications provided by our MPU manufacturer, the supported RAW formats are RAW8,10,12, NV12, NV21 and JPEG.
    Therefore, we are considering image sensors with RAW10,12 output formats, depending on the bandwidth requirements and compatibility with the proposed architecture.
    Thank you again for your support. We look forward to your recommendations regarding the most suitable SerDes devices for our architecture.
    Juan
  • Hello Juan,
    The UB960 is a good choice if the required bandwidth is within the specs.
    • DS90UB940N-Q1.
    • DS90UB940-Q1.
    This depends on which SER are you planning to use as your Uplink SER?
    Camera SER can be eithe the DS90UB935 or the DS90UB953. This depends on your exact Image sensor throughput.
    Uplink SER can only be the DS90UB971, but then you must use the DS90UB9722 as a compatible DES.
  • Hello Hamzeh,
    Thank you for your response. However, I believe there is still some misunderstanding regarding our requirements and the architecture we are trying to implement.
    We would like to clarify our requirements once again, as we need to finalize the SerDes device selection and proceed with our hardware design.
    1. External camera module – Four-channel deserializer
    Regarding the external camera module, we have absolutely no power supply restrictions. We can provide any voltage required by the selected SerDes devices.
    Our only requirement for this stage is to have a deserializer with four input ports to connect four cameras, each through its own serializer.
    Therefore, the DS90UB960-Q1 was just an initial candidate, but we are open to using any other compatible four-channel FPD-Link III deserializer you recommend.
    We would appreciate your recommendation regarding the most suitable four-channel deserializer and the corresponding camera serializers.
    The situation is different for the main PCB, where we have strict power supply constraints.
    After reviewing your product documentation, we have identified only the following FPD-Link III deserializers that appear to meet our power supply requirements:
    1. DS90UB940N-Q1.
    2. DS90UB940-Q1.
    These are the two devices we would like to evaluate for the main PCB.
    Could you please confirm whether either of these two deserializers can be used to receive the video stream from an external FPD-Link III serializer?
    Additionally, which of these two devices would you recommend for our application?
    3. Uplink serializer – Compatibility with the main PCB deserializer
    This is the most important point we need to clarify.
    Our proposed architecture requires an additional serializer (uplink serializer) in the external camera module.
    The connection would be as follows:
    • The 4 cameras with their corresponding serializer connect to a four-channel deserializer in the external module.
    • The MIPI CSI-2 output of this deserializer connects to the MIPI CSI-2 input of the uplink serializer.
    • The uplink serializer transmits the aggregated camera data to the deserializer on the main PCB.
    Therefore, we need a serializer that is compatible with either the DS90UB940N-Q1 or the DS90UB940-Q1.
    In your previous response, you recommended the DS90UB971-Q1 as the uplink serializer, together with the DS90UB922 deserializer.
    However, we have two concerns:
    • The DS90UB971-Q1 is an FPD-Link IV device.
    • We cannot find the DS90UB922 in your current product catalogue, and it appears to be a discontinued or obsolete device.
    Could you please clarify why you recommend this combination and, more importantly, whether there is an FPD-Link III serializer that can transmit the output of the external module deserializer to either the DS90UB940N-Q1 or DS90UB940-Q1?
    If such a combination exists, please specify the exact serializer and deserializer models.
    4. Final confirmation
    To avoid any further misunderstandings, we would appreciate a direct answer to the following questions:
    1. Given our limitations on the main board, and given that we have only found the DS90UB940N-Q1 or DS90UB940-Q1 as FPD-LINK III deserialisers that meet our power supply requirements, which uplink serialiser do you recommend we implement in the external module, between the output of the 4-input deserialiser on the external module and the input of one of these two deserialisers (DS90UB940N-Q1 or DS90UB940-Q1)?
    2. If this architecture is not possible with these devices, could you explain the specific technical limitation and recommend an alternative that meets our power supply constraints?
    3. We are currently focused on finalising the design of the main board; therefore, we simply need confirmation as to which of the two proposed deserialisers in our architecture (DS90UB940N-Q1 or DS90UB940-Q1) we can use in order to proceed with the design of our PCB, and we will then move on to designing the external module, selecting deserialisers/serialisers that are compatible with one of the two deserialisers implemented on the main board (DS90UB940N-Q1 or DS90UB940-Q1).
    Our intention is to maintain an FPD-Link architecture throughout the complete camera system, if technically possible.
    We would appreciate a clear recommendation of the specific serializer/deserializer models for both PCBs, including confirmation of their compatibility.
    Thank you for your understanding and support.
    Juan
  • Hello Juan,
    Can you please tell me in your words what exactly you are trying to achieve? I do not want to spend my time and your time reading all these AI generated posts and questions.
  • Hello Hamzeh,
    I do not fully understand this kind of response. I am simply describing our proposed architecture to help you understand what we are trying to implement and to ensure that the overall concept is properly understood.
    In your previous reply, you recommended the DS90UB922 deserializer for our main board. However, I have tried to find the DS90UB922 on the Texas Instruments website, but it does not appear in your product catalogue. Furthermore, I have found several discussions on TI forums indicating that the DS90UB922 has been discontinued for several years.
    Therefore, I do not understand why a product that is no longer in the catalogue is being recommended to us.
    Taking into account your previous replies, where we were informed that the proposed cascaded SerDes architecture is feasible, I would like to summarise the main question we need to resolve.
    Due to power supply limitations on our main board, we cannot easily provide additional 1.1 V or 1.8 V power rails. For this reason, we have identified two deserializers that could potentially meet our power supply requirements:
    • DS90UB940N-Q1.
    • DS90UB940-Q1.
    Both devices can operate with a 3.3 V supply and a 1.2 V
    Can either of these two deserializers be used in our proposed architecture, considering the features of the MIPI-CSI-2 controller in our MPU, as well as the specifications of our cameras, which have already been described in the previous messages of this ticket?
    I would appreciate a clear answer addressing this specific question so that we can move forward with the hardware design.
    Juan
  • Hello Juan,
    Maybe that was a typo. I wanted to recommend the DS90UB9722, not the DS90UB922.
    The UB9722 is a dual input FPD-Link4 Deserializer which has higher input bandwidth, and is compatible with the UB935/953 SERs.
    • DS90UB940N-Q1.
    • DS90UB940-Q1.
    The UB940 and the UB940N are not compatible with the SER UB953/935. Hence you can't use them here.
  • Hello Hamzeh,
    Since we do not have access to the complete datasheet of the DS90UB9722-Q1, could you please let us know its power supply requirements?
    If it can operate with a 1.2 V or 3.3 V supply, it would be a valid option for our application. Otherwise, we cannot use a deserializer on the main board that requires 1.1 V or 1.8 V supplies. This is precisely why I keep providing a summary of our proposed architecture.
    I would like to emphasise once again that the power supply limitation applies to the main board, not to the external camera module.
    For this reason, the deserializer on the main board must operate with a 1.2 V or 3.3 V supply. This is why we initially considered the following devices:
    • DS90UB940N-Q1.
    • DS90UB940-Q1.
    The only mandatory requirement is that the deserializer on the main board operates with a 1.2 V or 3.3 V supply. We have no particular restrictions regarding the other SerDes devices used in the external module, provided that they are compatible with the deserializer selected for the main board.
    We are therefore not obliged to use the SER UB953/935.
    I am attaching the proposed architecture diagram again for clarification.
    To summarise: the only mandatory requirement is that the deserializer on the main board operates with a 1.2 V or 3.3 V supply. The other SerDes devices used in the external module can have any power supply requirements, as long as they are compatible with the main board deserializer.
  • Hello Juan,
    The UB9722 requires 1.1V and 1.8V supply.
    I understand. But the UB940/N is not compatible with the UB935/953.
    Hence the question, what is the Image sensor interface to the SER? Is that MIPI CSI or can be anything else? That helps me suggest another SER
  • Hello Hamzeh,
    1. Understood. Are there any other serializers (SERs) that are compatible with the UB940/UB940N? Our intention is to use a deserializer operating with a 1.2 V or 3.3 V supply on the main board, and any SER/DES combination on the external camera module that allows us to connect four external cameras and deliver the video data to the MPU through its MIPI-CSI-2 interface.
    2. Regarding your question about the camera interface, if it is possible to use a camera with an interface other than MIPI-CSI-2 and still deliver the video data to the MPU through MIPI-CSI-2, we can adapt to any camera interface. The only mandatory requirement is that MIPI-CSI-2 reaches the MPU.
  • Hi Juan,
    We do not have any SER with MIPI CSI-2 interface that is compatible with the UB940/UB940N.
    You may use one of the following SER:
    1) The DS90UB929 - a SER with HDMI input interface and is compatible with the UB940/UB940N
    2) The DS90UB927 - a SER with LVDS (oLDI) input interface and is compatible with the UB940/UB940N
    3) The DS90UB925 - a SER with Parallel input interface and is compatible with the UB940/UB940N
    4) The DS90UB941AS - a SER with MIPI DSI input interface and is compatible with the UB940/UB940N
  • Hello Hamzeh,
    Understood. Therefore, based on your response, our proposed architecture could be as follows:
    We could use an HDMI camera connected to a DS90UB929 serializer. This would apply to all four cameras, each connected to its corresponding serializer. The outputs of these four serializers would then be connected to a four-input deserializer located in the external module.
    The output of this four-input deserializer would be connected to an uplink serializer, whose output would then be connected to the deserializer on the main board.
    Based on this configuration, we have three questions:
    1. Would the uplink serializer, located between the four-input deserializer in the external module and the deserializer on the main board, also need to be a DS90UB929?
    2. Which four-input deserializer should we use in the external module, between the four camera serializers and the uplink serializer?
    3. With this SerDes configuration, would remote I2C control from the MPU on the main board, through the UB940/UB940N deserializer, still be possible?
  • Hi Juan,
    I think that will not work. You can't pair the UB929 with the Quad DES such as the DSUB960.
    Question, why it is not possible to add a DC-DC converter on the main board to step down from 3.3V to 1.8V? That should be doable! If that is okay then your system would look like this:
    4x DS90UB935 ==> DS90UB960 ==> DS90UB971 ==> DS90UB9722.
    If that is not possible, I do not think there is a suitable solution for you in our portfolio.
  • Hi Hamzeh,
    This has been a requirement from the very beginning of the ticket. On the main board, we can only provide 3.3 V and 1.2 V power supplies.
    I do not fully understand why the UB940/UB940N deserializers, which convert FPD-Link III to MIPI-CSI-2, cannot be used with a MIPI-CSI-2 to FPD-Link III serializer, resulting in the following architecture:
    4x DS90UB935 ==> DS90UB960 ==> DS90UB935 ==> DS90UB940
    The architecture would consist of:
    Four DS90UB935 serializers, converting MIPI-CSI-2 to FPD-Link III, connected to the DS90UB960 deserializer, which converts FPD-Link III to MIPI-CSI-2.
    The DS90UB960 output would then be connected to another DS90UB935 serializer, converting MIPI-CSI-2 back to FPD-Link III.
    Finally, this serializer would be connected to the DS90UB940 deserializer on the main board, which converts FPD-Link III to MIPI-CSI-2.
    Therefore, the interfaces and protocols between the output of each device and the input of the next device appear to be compatible.
    Could you please clarify why this architecture would not work?
  • Hi Juan,
    This will not work. The UB935 is not compatible with the UB940/UB940N.
    Another option is to us an SoC (Image processor) to convert the output of the UB960 from MIPI CSI-2 to MIPI DSI or to oLDI then use the DS90UB941AS or the DS90UB947 ==> DS90UB940/940N
