TCAN6062-Q1: ResXL bit and stabilization time,
Part Number: TCAN6062-Q1
Other Parts Discussed in Thread: TCAN6062,
Hello Experts,
Could you please help these several questions?
I have a question about the transceiver, as follows.You stated the following about FAST mode:
“When the TXD pin is LOW for at least tSELECT, FAST TX mode becomes pre-selected. After this pre-selection, two valid consecutive low-to-high rising edges on TXD within tSymbolNom will cause the device to transition to FAST TX mode.”
I mapped this process to the CAN XL frame as shown below:
We have the tSELECT requirement as shown below:
Based on my mapping picture, should we hold the resXL bit for longer than 500 ns so that the transceiver can become pre-selected? Is that correct?This is because, at the ADH bit, CAN XL starts generating PWM, where there are two valid consecutive low-to-high rising edges on TXD within tSymbolNom.
for the second question:
If CAN XL generates a frame as shown in the preceding picture, after tSELECT, the transceiver becomes pre-selected. If, at T1, it detects one rising edge (a pulse like the one shown at T1 in the picture), and then the time exceeds tSymbolNom (205 ns) before another valid rising edge occurs (still can not detect the second valid rising edge), is the transceiver still in the pre-selected state?
  • If not, will the PWM starting from T4 (two valid consecutive low-to-high rising edges) not be detected, and will the transceiver still operate in normal mode with NRZ encoding? Can it still switch to FAST mode?
  • Do we need to hold TXD at level 0 for tSELECT again so that the transceiver can return to the pre-selected state?
  • Is there any way for the transceiver to remain in the pre-selected state in this case and still detect the two valid consecutive low-to-high rising edges at T4 and switch to FAST mode?
  • I have another question about the stabilization time after the transceiver starts switching from SIC mode to FAST mode.
    In this picture, after T1, the transceiver detects two valid rising edges within 205 ns. After the second rising edge, the transceiver starts switching from SIC mode to FAST mode.
    I would like to ask about the value of tStable, as shown below:
    tStable = the time from the second valid rising edge, when the transceiver starts switching mode, until the transceiver becomes stable in FAST mode.
    By “stable in FAST mode,” I mean that the CANH and CANL signals , when these signals become stable, and therefore the CAN bus, have reached a stable FAST-mode level.
    Could you please confirm whether this stabilization time is specified in the datasheet? If so, what is the maximum value of tStable?
    The device expert supporting TCAN6062 is currently out of office, please expect a respond by Monday next week.
    Thank you for the patience.
  • Hi 종길 임,
    1.  Yes, provided RESXL corresponds to TXD low where TXD remains low for at least 500 ns minimum and 980 ns maximum. and once pre-selected, two valid consecutive TXD low to high transitions within tsymbolNom (45 to 205 ns) should then trigger FAST TX mode.
    2. Yes, T1 rising edge alone should not trigger TX mode and the 2 qualifying rising edges must occur within tsymbolNom. Hence, should not qualify if T1 to the next edge exceeds 205 ns and should then trigger FAST TX if still pre-selected when T4 and T5 provide two new valid consecutive rising edges. Note that TXD low for tselect, then two valid consecutive rising edges within tSymbolNom is the sequence and no other alternate mechanism for entering or holding pre-selection described and should still be in the SIC mode. Hence, to ensure reliable FAST TX entry, would recommend to re-establish TXD LOW for at least tselect before the qualifying PWM sequence if pre-selection may have been lost.
    3.  The data sheet specifies tprop(BusDom-BusLevel0) as the delay from SIC-to-FAST TX mode change until the CAN bus reaches level_0. Hence, 80 ns max, thanks.
    Michael.
  • Thank you for your confirmation, but there is still an unclear point in your answer that I would like to confirm again.
    1.  Do you mean that after T2, when the time exceeds tSymbolNom (205 ns) and the transceiver has not detected the second rising edge, the transceiver is still in the FAST TX pre-selected state? Is that correct?
    2. At T3, TXD still holds logical 0. After detecting two valid rising edges at T4, the transceiver will change to FAST TX mode at T5. Is that correct?
    3. “The data sheet specifies tProp(BusDom-BusLevel0) as the delay from the SIC-to-FAST TX mode change until the CAN bus reaches level_0. Hence, 80 ns max.”
      How about the case where we use PWM_1 to trigger the transceiver to FAST TX mode? What is the corresponding tProp(BusDom-BusLevel1)?
    Please don't mix multiple answers together, as it can make me confused. Please separate the answer for each question.
  • Hi 종길 임,
    1. I would not assume the device remains in pre-selected mode. I.e, the important detail is Figure 7-8 in Section 7.3.3.3 of the TCAN6062-Q1 data sheet where the figure illustrates a second LOW interval before FAST TX pre-selection is established for the subsequent valid PWM edge pair. Hence, for your T1: First rising edge occurs. T2: The interval for tsymbolNom(max) is exceeded and the edge pair is not valid. Hence, the device is in SIC mode until the second rising edge per tsymbol(Nom) as shown below and the recommendation to ensure the LOW interval after the unsuccessful T1 sequence satisfying tSELECT before the T4 / T5 qualifying edges.
    2. Yes, I.e., if TXD remains LOW for at least tSELECT again, FAST TX becomes pre-selected and T4 and T5 would be where the two valid consecutive rising edges within 205 ns triggers FAST TX mode.
    3. This is also specified in the data sheet as 80 ns max, thanks.
    Michael.
  • Hi Experts,
    Thank you for your clarification.
    I understand your answers to questions 2 and 3, but I am still confused about your answer to question 1.
    I am having difficulty determining whether our current design is compatible with your transceiver. Since you are the expert on this transceiver, I would really appreciate your support in confirming whether it can work correctly with our waveform.
    According to ISO 11898-2, the pre-selection mechanism is described as follows:
    "The PMA shall distinguish the required behaviour based on the last received bit level on pin TXD without PWM encoding. FAST TX mode shall be preselected, if there is a consecutive logical 0 on pin TXD detected for tSelect. FAST RX shall be preselected, if there is a consecutive logical 1 on pin TXD detected for tSelect. Based on the preselected mode the PMA shall execute the mode transition with the first detected PWM symbol"
    Based on this description, my understanding is that the pre-selection state changes only when TXD remains at logical 0 or logical 1 for at least tSELECT.
    Therefore, I assume that a short HIGH pulse (Tpulse <= 100 ns) cannot change the pre-selection state because its duration is much shorter than tSELECT (980 ns).
    Let me explain my understanding using the attached waveform.
    Step 1: FAST TX pre-selection
    From T0 to T4, TXD remains at logical 0 for more than 980 ns (tSELECT).
    Therefore, the transceiver changes its pre-selection state from FAST RX pre-selected to FAST TX pre-selected while remaining in Normal (SIC) mode.
    Step 2: Unexpected HIGH pulse at T5
    Due to an issue in our CAN controller, an unexpected short HIGH pulse appears on TXD at T5.
    The duration of this pulse is less and equal than 100 ns (Tpulse <= 100 ns), which is much shorter than tSELECT (980 ns).
    Based on my understanding of the ISO specification, this short HIGH pulse should not cause the pre-selection state to change from FAST TX to FAST RX.
    Therefore, transceiver remains in the FAST TX pre-selected state after this unexpected pulse.
    Step 3: Interval after the unexpected pulse
    After the short HIGH pulse at T5, TXD returns to logical 0 and remains LOW during T6 and T7.
    However, this LOW interval is shorter than tSELECT (980 ns).
    My understanding is that this should not be a problem because FAST TX was already pre-selected before the unexpected HIGH pulse, and the short pulse at T5 should not have changed that state.
    Step 4: Switching to TX FAST mode
    After T8, the transceiver detects two valid consecutive LOW-to-HIGH rising edges within 205 ns.
    Since FAST TX is still pre-selected, the transceiver should switch from Normal (SIC) mode to TX FAST mode when the second valid rising edge is detected at T8. and switch to TX FAST mode at T9
    My question is:
    1. Is my understanding correct?
    2. Can your transceiver switch to TX FAST mode at T9 with my waveform?
    Khoa
  • Hi Khoa,
    Thanks for sharing the full context / duration.
    1. Yes your understanding is correct as the pre-selection state should change based on detecting a continuous TXD low / high for at least tSELECT. Which is not the case here, with T5 being shorter.
    2. Yes based on the full waveform, this should be the case, thanks.
    Michael.
