TMDS261B I2C
Other Parts Discussed in Thread: TMDS261B
Can I use the LP pin to disable TMDS261B  (I2C) in order to have two parts on the board with the same device address?   If each part has its own enable then one can be disabled while the other one is accessed.  I know there will not be video when the TMDS261B is disabled but will it keep its configuration registers settings that were set before the disable or would they all have to be written again each time the part is enabled?
