TUSB2077A max trace length
Other Parts Discussed in Thread: TUSB2077A, AM3894
For TUSb2077A USB hub, I would like to know the max trace length that can be used for the down stream ports to a back panel and front panel. I came across the link below in another posting on e2e.
http://www.usb.org/developers/docs/hs_usb_pdg_r1_0.pdf
Can this part drive 18 inches length as suggested in this Intel design guideline ?
Also, what is the max trace length that can be used for AM3894's USB port ?
Lakshmi
  • The TUSB2077A is a USB full-speed hub with a maximum data transfer speed of 12 Mb/s.
    The Intel guidelines you linked to are for USB high-speed (480 Mb/s) connections which obviously prenet a mcuh greater challenge than does 12 Mb/s.
    There should not be any issues in driving 18" of trace.
    As far as comment on the AM3894, you will need to postthat question in the Sitara MPU Forum.
