Confirm XIO2001 Schematic
Other Parts Discussed in Thread: XIO2001
8738.MR-100-V1.0-PCI.PDF
Hi, I designed with xio2001.
Would you review the schematic?
< environment >
1)     CPU  : Freescale P1010  OS :   linux
2)     33Mhz PCI BUS
3)     On board
<Check Point>
Is EEPROM in GPIO[4:3] is mandatory?
Please review PCIR1, PCIR2 and the configuration of other pins.
Thank you.
    We are reviewing your schematic and will reply soon.
    Regards.
    I have only 3 comments:
    1) If JTAG interface is not used: JTAG_TRST and JTAG_TCK should be pulled down, all other JTAG terminals can be left  floating.
    2) The AC coupling capacitors on TXP and TXN of the XIO2001, have to be close to the PCIe connector.
    3) Connect PCIR to the clamp I/O voltage through a 1K resistor.
    Also, make sure you follow the power-up sequence described on Section 3.1.1 of Data Manual.
    Regards.
  • Thank you very much!!
  • U-Boot 2010.12 (Jun 22 2012 - 09:50:47)
    CPU:   P1010, Version: 1.0, (0x80f10010)
    Core:  E500, Version: 5.1, (0x80212151)
    testSis >>>>>> plat_ratio=5 CONFIG_SYS_CLK_FREQ=66666666 freqSystemBus=13de4352
    testSis >>>>>>>> freqProcessor >> 2 i=0 gur->porpllsr=4444140a e500_ratio=4 half_freqSystemBus=9ef21a9
    testSis >>>> P1010E
    Clock Configuration:
           CPU0:666.667 MHz,
           CCB:333.333 MHz,
    testSis >>>> DDR 2
           DDR:333.333 MHz (666.667 MT/s data rate) (Asynchronous), IFC:83.333 MHz
    L1:    D-cache 32 kB enabled
           I-cache 32 kB enabled
    Board: P1010RDB
    I2C:   ready
    SPI:   ready
    DRAM:  testSis >>>>>>>>>> 111
    DDR: failed to read SPD from address 82
    SPD error! Trying fallback to raw timing calculation
    Detected UDIMM(s)
    testSis >>>> CONFIG_SYS_MEMTEST_START=0 CONFIG_SYS_MEMTEST_END=1fffffff
    SDRAM Memory Test : 0x00000000 - 0x1fffffff
    0 SDRAM test phase 1: 0xAAAAAAAA
    0 SDRAM test phase 2: 0x55555555
    0 SDRAM test phase 3: 0xAAAAAAAA / 0x55555555
    0 SDRAM test phase 4: Address
    0 SDRAM test passed.
    DDR: 1 GiB (DDR3, 32-bit, CL=5, ECC off)
    FLASH: 32 MiB
    L2:    256 KB enabled
    NAND:  No NAND device found!!!
    0 MiB
    PCIe1: Root Complex of mini PCIe Slot, no link, regs @ 0xffe0a000
    PCIe1: Bus 00 - 00
    PCIe2: Root Complex of PCIe Slot, x1, regs @ 0xffe09000
      02:00.0     - 104c:8240 - Bridge device
       03:00.0    - 9339:4ff0 - Multimedia device
       03:01.0    - 17a1:0300 - Multimedia device
    PCIe2: Bus 01 - 03
    In:    serial
    Out:   serial
    Err:   serial
    Net:   PHY Info(eTSEC1): PHY ID 0x001cc912 ... 20 (RTL8211B/CL)
           PHY Info(eTSEC2): PHY ID 0xffffffff ... 22 (Unknown/Generic PHY)
    eTSEC2: No support for PHY id ffffffff; assuming generic
           PHY Info(eTSEC3): PHY ID 0xffffffff ... 22 (Unknown/Generic PHY)
    eTSEC3: No support for PHY id ffffffff; assuming generic
    eTSEC1, eTSEC2, eTSEC3
    Hit any key to stop autoboot:  0
    WARNING: adjusting available memory to 30000000
    ## Booting kernel from Legacy Image at ee020000 ...
       Image Name:   Linux-2.6.35
       Created:      2012-07-04   1:55:37 UTC
       Image Type:   PowerPC Linux Kernel Image (gzip compressed)
       Data Size:    3250090 Bytes = 3.1 MiB
       Load Address: 00000000
       Entry Point:  00000000
       Verifying Checksum ... OK
    ## Loading init Ramdisk from Legacy Image at ee420000 ...
       Image Name:   uboot ext2 ramdisk rootfs
       Created:      2012-07-03   2:36:46 UTC
       Image Type:   PowerPC Linux RAMDisk Image (gzip compressed)
       Data Size:    8261585 Bytes = 7.9 MiB
    ## Flattened Device Tree blob at ee000000
       Booting using the fdt blob at 0xee000000
       Uncompressing Kernel Image ... OK
       Loading Ramdisk to 2f81f000, end 2fffffd1 ... OK
       Loading Device Tree to 00ff9000, end 00fff3a5 ... OK
    Using P1010 RDB machine description
    Memory CAM mapping: 256/256/256 Mb, residual: 236Mb
    Linux version 2.6.35 (freeten@vulcan) (gcc version 4.5.1 (Sourcery G++ Lite 2010.09-55) ) #10 Wed Jul 4 10:48:41 KST 2012
    Found initrd at 0xef81f000:0xefffffd1
    bootconsole [udbg0] enabled
    setup_arch: bootmem
    p1010_rdb_setup_arch()
    Found FSL PCI host bridge at 0x00000000ffe09000. Firmware bus number: 0->255
    PCI host bridge /pcie@ffe09000  ranges:
     MEM 0x00000000a0000000..0x00000000bfffffff -> 0x00000000a0000000
      IO 0x00000000ffc10000..0x00000000ffc1ffff -> 0x0000000000000000
    /pcie@ffe09000: PCICSRBAR @ 0xfff00000
    Found FSL PCI host bridge at 0x00000000ffe0a000. Firmware bus number: 0->255
    PCI host bridge /pcie@ffe0a000  ranges:
     MEM 0x0000000080000000..0x000000009fffffff -> 0x0000000080000000
      IO 0x00000000ffc00000..0x00000000ffc0ffff -> 0x0000000000000000
    /pcie@ffe0a000: PCICSRBAR @ 0xfff00000
    P1010 RDB board from Freescale Semiconductor
    arch: exit
    Zone PFN ranges:
      DMA      0x00000000 -> 0x00030000
      Normal   empty
      HighMem  0x00030000 -> 0x0003ec00
    Movable zone start PFN for each node
    early_node_map[1] active PFN ranges
        0: 0x00000000 -> 0x0003ec00
    MMU: Allocated 1088 bytes of context maps for 255 contexts
    Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 255016
    Kernel command line: root=/dev/ram rw console=ttyS0,115200 ramdisk_size=600000 mem=1004M
    PID hash table entries: 4096 (order: 2, 16384 bytes)
    Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
    Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
    Memory: 1004420k/1028096k available (6224k kernel code, 23676k reserved, 280k data, 176k bss, 204k init)
    Kernel virtual memory layout:
      * 0xfffcf000..0xfffff000  : fixmap
      * 0xff800000..0xffc00000  : highmem PTEs
      * 0xff7d8000..0xff800000  : early ioremap
      * 0xf1000000..0xff7d8000  : vmalloc & ioremap
    SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    Hierarchical RCU implementation.
            RCU-based detection of stalled CPUs is disabled.
            Verbose stalled-CPUs detection is disabled.
    NR_IRQS:512
    mpic: Setting up MPIC " OpenPIC  " version 1.2 at ffe40000, max 1 CPUs
    mpic: ISU size: 256, shift: 8, mask: ff
    mpic: Initializing for 256 sources
    clocksource: timebase mult[6000002] shift[22] registered
    Console: colour dummy device 80x25
    pid_max: default: 32768 minimum: 301
    Mount-cache hash table entries: 512
    xor: measuring software checksum speed
       8regs     :   818.000 MB/sec
       8regs_prefetch:   704.000 MB/sec
       32regs    :   814.000 MB/sec
       32regs_prefetch:   724.000 MB/sec
    xor: using function: 8regs (818.000 MB/sec)
    NET: Registered protocol family 16
    PCI: Probing PCI hardware
    pci 0000:00:00.0: ignoring class b20 (doesn't match header type 01)
    pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    pci 0000:01:00.0: PCI bridge to [bus 02-ff]
    pci 0001:03:00.0: ignoring class b20 (doesn't match header type 01)
    pci 0001:03:00.0: PCI bridge to [bus 04-ff]
    pci 0000:01:00.0: PCI bridge to [bus 02-02]
    pci 0000:01:00.0:   bridge window [io  0xff7ed000-0xff7edfff]
    pci 0000:01:00.0:   bridge window [mem 0xa0000000-0xa7ffffff]
    pci 0000:01:00.0:   bridge window [mem pref disabled]
    pci 0000:00:00.0: not setting up bridge for bus 0000:01
    pci 0001:03:00.0: not setting up bridge for bus 0001:04
    bio: create slab <bio-0> at 0
    vgaarb: loaded
    SCSI subsystem initialized
    usbcore: registered new interface driver usbfs
    usbcore: registered new interface driver hub
    usbcore: registered new device driver usb
    raid6: int32x1     95 MB/s
    raid6: int32x2    167 MB/s
    raid6: int32x4    238 MB/s
    raid6: int32x8    199 MB/s
    raid6: using algorithm int32x4 (238 MB/s)
    Freescale Elo / Elo Plus DMA driver
    Switching to clocksource timebase
    NET: Registered protocol family 2
    IP route cache hash table entries: 32768 (order: 5, 131072 bytes)
    TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
    TCP bind hash table entries: 65536 (order: 6, 262144 bytes)
    TCP: Hash tables configured (established 131072 bind 65536)
    TCP reno registered
    UDP hash table entries: 512 (order: 1, 8192 bytes)
    UDP-Lite hash table entries: 512 (order: 1, 8192 bytes)
    RPC: Registered udp transport module.
    RPC: Registered tcp transport module.
    RPC: Registered tcp NFSv4.1 backchannel transport module.
    Trying to unpack rootfs image as initramfs...
    rootfs image is not initramfs (no cpio magic); looks like an initrd
    Freeing initrd memory: 8067k freed
    fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
    fsl-elo-dma ffe21300.dma: #0 (fsl,eloplus-dma-channel), irq 20
    fsl-elo-dma ffe21300.dma: #1 (fsl,eloplus-dma-channel), irq 21
    fsl-elo-dma ffe21300.dma: #2 (fsl,eloplus-dma-channel), irq 22
    fsl-elo-dma ffe21300.dma: #3 (fsl,eloplus-dma-channel), irq 23
    highmem bounce pool size: 64 pages
    Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
    Slow work thread pool: Starting up
    Slow work thread pool: Ready
    JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    SGI XFS with security attributes, large block/inode numbers, no debug enabled
    msgmni has been set to 1505
    alg: No test for stdrng (krng)
    async_tx: api initialized (async)
    io scheduler noop registered
    io scheduler deadline registered
    io scheduler cfq registered (default)
    Generic non-volatile memory driver v1.1
    Serial: 8250/16550 driver, 2 ports, IRQ sharing enabled
    serial8250.0: ttyS0 at MMIO 0xffe04500 (irq = 42) is a 16550A
    console [ttyS0] enabled, bootconsole disabled
    serial8250.0: ttyS1 at MMIO 0xffe04600 (irq = 42) is a 16550A
    brd: module loaded
    st: Version 20081215, fixed bufsize 32768, s/g segs 256
    fsl-sata ffe18000.sata: Sata FSL Platform/CSB Driver init
    scsi0 : sata_fsl
    ata1: SATA max UDMA/133 irq 74
    fsl-sata ffe19000.sata: Sata FSL Platform/CSB Driver init
    scsi1 : sata_fsl
    ata2: SATA max UDMA/133 irq 41
    ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    Amd/Fujitsu Extended Query Table at 0x0040
    number of CFI chips: 1
    RedBoot partition parsing not available
    Creating 7 MTD partitions on "ee000000.nor":
    0x000000000000-0x000000020000 : "NOR DTB Image"
    ata2: Signature Update detected @ 0 msecs
    ftl_cs: FTL header not found.
    0x000000020000-0x000000420000 : "NOR Linux Kernel Image"
    0x000000420000-0x000000c20000 : "NOR Root File System"
    0x000000c20000-0x000001920000 : "NOR jffs2 File System"
    0x000001920000-0x000001c20000 : "Logo Area"
    0x000001c20000-0x000001f00000 : "CramFS File System"
    0x000001f60000-0x000002000000 : "NOR U-Boot Image"
    No NAND device found.
    Fixed MDIO Bus: probed
    e1000e: Intel(R) PRO/1000 Network Driver - 1.0.2-k4
    e1000e: Copyright (c) 1999 - 2009 Intel Corporation.
    /proc/ptp_1588 created
    IEEE1588: ptp-timer devicepresent in the system
    IEEE1588: ptp-timer initialized
    eth0: Gianfar Ethernet Controller Version 1.4-skbr1.1.5, 00:19:19:02:60:f6
    eth0: Running with NAPI enabled
    eth0: RX BD ring size for Q[0]: 128
    eth0: RX BD ring size for Q[1]: 128
    eth0: RX BD ring size for Q[2]: 128
    eth0: RX BD ring size for Q[3]: 128
    eth0: RX BD ring size for Q[4]: 128
    eth0: RX BD ring size for Q[5]: 128
    eth0: RX BD ring size for Q[6]: 128
    eth0: RX BD ring size for Q[7]: 128
    eth0: TX BD ring size for Q[0]: 128
    eth0: TX BD ring size for Q[1]: 128
    eth0: TX BD ring size for Q[2]: 128
    eth0: TX BD ring size for Q[3]: 128
    eth0: TX BD ring size for Q[4]: 128
    eth0: TX BD ring size for Q[5]: 128
    eth0: TX BD ring size for Q[6]: 128
    eth0: TX BD ring size for Q[7]: 128
    eth1: Gianfar Ethernet Controller Version 1.4-skbr1.1.5, 00:00:00:00:00:00
    eth1: Running with NAPI enabled
    eth1: RX BD ring size for Q[0]: 128
    eth1: RX BD ring size for Q[1]: 128
    eth1: RX BD ring size for Q[2]: 128
    eth1: RX BD ring size for Q[3]: 128
    eth1: RX BD ring size for Q[4]: 128
    eth1: RX BD ring size for Q[5]: 128
    eth1: RX BD ring size for Q[6]: 128
    eth1: RX BD ring size for Q[7]: 128
    eth1: TX BD ring size for Q[0]: 128
    eth1: TX BD ring size for Q[1]: 128
    eth1: TX BD ring size for Q[2]: 128
    eth1: TX BD ring size for Q[3]: 128
    eth1: TX BD ring size for Q[4]: 128
    eth1: TX BD ring size for Q[5]: 128
    eth1: TX BD ring size for Q[6]: 128
    eth1: TX BD ring size for Q[7]: 128
    ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
    eth2: Gianfar Ethernet Controller Version 1.4-skbr1.1.5, 00:00:00:00:00:00
    eth2: Running with NAPI enabled
    eth2: RX BD ring size for Q[0]: 128
    eth2: RX BD ring size for Q[1]: 128
    eth2: RX BD ring size for Q[2]: 128
    eth2: RX BD ring size for Q[3]: 128
    eth2: RX BD ring size for Q[4]: 128
    eth2: RX BD ring size for Q[5]: 128
    eth2: RX BD ring size for Q[6]: 128
    eth2: RX BD ring size for Q[7]: 128
    eth2: TX BD ring size for Q[0]: 128
    eth2: TX BD ring size for Q[1]: 128
    eth2: TX BD ring size for Q[2]: 128
    eth2: TX BD ring size for Q[3]: 128
    eth2: TX BD ring size for Q[4]: 128
    eth2: TX BD ring size for Q[5]: 128
    eth2: TX BD ring size for Q[6]: 128
    eth2: TX BD ring size for Q[7]: 128
    ata2.00: ATA-8: WDC WD20EARX-00PASB0, 51.0AB51, max UDMA/133
    ata2.00: 3907029168 sectors, multi 0: LBA48 NCQ (depth 16/32)
    Freescale PowerQUICC MII Bus: probed
    mdio_bus mdio@ffe24000: error probing PHY at address 0
    mdio_bus mdio@ffe24000: error probing PHY at address 2
    ata2.00: configured for UDMA/133
    ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    fsl-ehci fsl-ehci.0: Freescale On-Chip EHCI Host Controller
    fsl-ehci fsl-ehci.0: new USB bus registered, assigned bus number 1
    fsl-ehci fsl-ehci.0: irq 28, io base 0xffe22000
    fsl-ehci fsl-ehci.0: USB 2.0 started, EHCI 1.00
    usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    usb usb1: Product: Freescale On-Chip EHCI Host Controller
    usb usb1: Manufacturer: Linux 2.6.35 ehci_hcd
    usb usb1: SerialNumber: fsl-ehci.0
    hub 1-0:1.0: USB hub found
    hub 1-0:1.0: 1 port detected
    ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    Initializing USB Mass Storage driver...
    usbcore: registered new interface driver usb-storage
    USB Mass Storage support registered.
    usbcore: registered new interface driver ums-alauda
    usbcore: registered new interface driver ums-cypress
    usbcore: registered new interface driver ums-datafab
    usbcore: registered new interface driver ums-freecom
    usbcore: registered new interface driver ums-isd200
    usbcore: registered new interface driver ums-jumpshot
    usbcore: registered new interface driver ums-karma
    usbcore: registered new interface driver ums-onetouch
    usbcore: registered new interface driver ums-sddr09
    usbcore: registered new interface driver ums-sddr55
    ata1: No Device OR PHYRDY change,Hstatus = 0xa0000000
    ata1: SATA link down (SStatus 0 SControl 300)
    scsi 1:0:0:0: Direct-Access     ATA      WDC WD20EARX-00P 51.0 PQ: 0 ANSI: 5
    usbcore: registered new interface driver ums-usbat
    mice: PS/2 mouse device common for all mice
    sd 1:0:0:0: [sda] 3907029168 512-byte logical blocks: (2.00 TB/1.81 TiB)
    sd 1:0:0:0: [sda] 4096-byte physical blocks
    sd 1:0:0:0: [sda] Write Protect is off
    sd 1:0:0:0: Attached scsi generic sg0 type 0
    sd 1:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
    i2c /dev entries driver
     sda:
    rtc-pt7c4338 0-0068: rtc core: registered pt7c4338 as rtc0
    md: raid6 personality registered for level 6
    md: raid5 personality registered for level 5
    md: raid4 personality registered for level 4
    sdhci: Secure Digital Host Controller Interface driver
    sdhci: Copyright(c) Pierre Ossman
    mmc0: SDHCI controller on ffe2e000.sdhci [ffe2e000.sdhci] using DMA
    of_platform ffe01000.jr: failed to flush job queue 0
    of_platform ffe02000.jr: failed to flush job queue 1
    of_platform ffe03000.jr: failed to flush job queue 2
    of_platform ffe04000.jr: failed to flush job queue 3
    caam ffe30000.crypto: device ID = 0x0a14010000000000
    caam ffe30000.crypto: job queues = 4
    caam ffe30000.crypto: algapi error in job queue registration: -19
    usbcore: registered new interface driver usbhid
    usbhid: USB HID core driver
    IPv4 over IPv4 tunneling driver
    GRE over IPv4 tunneling driver
    TCP cubic registered
    Initializing XFRM netlink socket
    NET: Registered protocol family 10
    IPv6 over IPv4 tunneling driver
    NET: Registered protocol family 17
    NET: Registered protocol family 15
    802.1Q VLAN Support v1.8 Ben Greear <greearb@candelatech.com>
    All bugs added by David S. Miller <davem@redhat.com>
    rtc-pt7c4338 0-0068: setting system clock to 2011-01-17 13:36:28 UTC (1295271388)
    usb 1-1: new full speed USB device using fsl-ehci and address 2
    usb 1-1: device descriptor read/64, error -71
     sda1 sda2 sda3 sda4
    sd 1:0:0:0: [sda] Attached SCSI disk
    md: Waiting for all devices to be available before autodetect
    md: If you don't use raid, use raid=noautodetect
    md: Autodetecting RAID arrays.
    md: Scanned 0 and added 0 devices.
    md: autorun ...
    md: ... autorun DONE.
    RAMDISK: gzip image found at block 0
    usb 1-1: new full speed USB device using fsl-ehci and address 3
    VFS: Mounted root (ext2 filesystem) on device 1:0.
    Freeing unused kernel memory: 204k init
    usb 1-1: new full speed USB device using fsl-ehci and address 4
    usb 1-1: device not accepting address 4, error -71
    usb 1-1: new full speed USB device using fsl-ehci and address 5
    usb 1-1: device not accepting address 5, error -71
    hub 1-0:1.0: unable to enumerate USB device on port 1
    ADDRCONF(NETDEV_UP): eth0: link is not ready
    sh: 1: unknown operand
    PHY: mdio@ffe24000:01 - Link is Up - 100/Full
    ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Welcome to HT DVR.
    dvr login: root
    Password:
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# GG
    ftpget wrk/dhsul/HW_TEST/Nova2/driver.ko
    ftpget wrk/dhsul/HW_TEST/Nova2/nova
    driver: module license 'unspecified' taints kernel.
    Disabling lock debugging due to kernel taint
    MAX Memory: 1004MB (0x3ec00000)
    >>>>> AST1200 0 PCI IRQ=16(16)
     >>   0: 0 pciReg(P)=0xA0008000  decMem(P)=0x3EC00000  encMem(P)=0x3F000000
    >>>>> Chip 0 PCI Config 0x40: 0x0185BB5F
    >>>>> Chip 0 PCI Config 0x3C: 0x81810308
    initAstHwPageBuffer: chipId=0 decPageBase=0xc0 encPageBase=0x0
    INPUT_RESOL chipId[0]=(0x21c, 0x0, 0x0, 0x0)
    inputModeHD=1
    Manual MAX Setting: AST-1200
                        max=1
                    maxChan=4
                 maxChanbit=0xf
    mdin380: MMIO base=0xA4000000   len=0x04000000
    mdin380: MMIO  end=0xA7FFFFFF flags=0x00042208
    VGA Controller: MDIN-380 ...
    >>> initI2cNap9004(samplingRate=1): id=0 ... done (0)
    driver loaded: 08:54:32, Aug  7 2012
    EXT3-fs: barriers not enabled
    kjournald starting.  Commit interval 5 seconds
    EXT3-fs (sda3): warning: maximal mount count reached, running e2fsck is recommended
    EXT3-fs (sda3): using internal journal
    EXT3-fs (sda3): mounted filesystem with writeback data mode
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# lspci
    00:00.0 Class 0b20: Unknown device 1957:0129 (rev 10)
    01:00.0 Class 0604: Unknown device 104c:8240
    02:00.0 Class 0480: Unknown device 9339:4ff0 (rev 08)
    02:01.0 Class 0400: Unknown device 17a1:0300
    03:00.0 Class 0b20: Unknown device 1957:0129 (rev 10)
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# xio
    Adress 0x80010000 is 0x8240104c
    Adress 0x80010004 is 0x00100007
    Adress 0x80010008 is 0x06040000
    Adress 0x8001000c is 0x00010008
    Adress 0x80010010 is 0x00000000
    Adress 0x80010014 is 0x00000000
    Adress 0x80010018 is 0x00020201
    Adress 0x8001001c is 0x02a01111
    Adress 0x80010020 is 0xa7f0a000
    Adress 0x80010024 is 0x0001fff1
    Adress 0x80010028 is 0x00000000
    Adress 0x8001002c is 0x00000000
    Adress 0x80010030 is 0x00000000
    Adress 0x80010034 is 0x00000040
    Adress 0x80010038 is 0x00000000
    Adress 0x8001003c is 0x000000ff
    Adress 0x80010040 is 0x0000480d
    Adress 0x80010044 is 0x00000000
    Adress 0x80010048 is 0x06035001
    Adress 0x8001004c is 0x00400008
    Adress 0x80010050 is 0x00887005
    Adress 0x80010054 is 0x00000000
    Adress 0x80010058 is 0x00000000
    Adress 0x8001005c is 0x00000000
    Adress 0x80010060 is 0x00000000
    Adress 0x80010064 is 0x00000000
    Adress 0x80010068 is 0x00000000
    Adress 0x8001006c is 0x00000000
    Adress 0x80010070 is 0x00720010
    Adress 0x80010074 is 0x003c8002
    Adress 0x80010078 is 0x00112000
    Adress 0x8001007c is 0x00064c11
    Adress 0x80010080 is 0x10110000
    Adress 0x80010084 is 0x00000000
    Adress 0x80010088 is 0x00000000
    Adress 0x8001008c is 0x00000000
    Adress 0x80010090 is 0x00000000
    Adress 0x80010094 is 0x00000000
    Adress 0x80010098 is 0x00000000
    Adress 0x8001009c is 0x00000000
    Adress 0x800100a0 is 0x00000000
    Adress 0x800100a4 is 0x00000000
    Adress 0x800100a8 is 0x00000000
    Adress 0x800100ac is 0x00000000
    Adress 0x800100b0 is 0x09000000
    Adress 0x800100b4 is 0x001f0000
    Adress 0x800100b8 is 0x00000000
    Adress 0x800100bc is 0x00000000
    Adress 0x800100c0 is 0x01000001
    Adress 0x800100c4 is 0x00120108
    Adress 0x800100c8 is 0x32142000
    Adress 0x800100cc is 0x00000000
    Adress 0x800100d0 is 0x00000000
    Adress 0x800100d4 is 0x8600025f
    Adress 0x800100d8 is 0x00000000
    Adress 0x800100dc is 0x00000040
    Adress 0x800100e0 is 0x00000000
    Adress 0x800100e4 is 0x00000000
    Adress 0x800100e8 is 0x00080443
    Adress 0x800100ec is 0x01c0007f
    Adress 0x800100f0 is 0x00000000
    Adress 0x800100f4 is 0x00000000
    Adress 0x800100f8 is 0x00000000
    Adress 0x800100fc is 0x00000000
    Adress 0x81010000 is 0x00010001
    Adress 0x81010004 is 0x00000000
    Adress 0x81010008 is 0x00000000
    Adress 0x8101000c is 0x00062031
    Adress 0x81010010 is 0x00002000
    Adress 0x81010014 is 0x00002000
    Adress 0x81010018 is 0x000000a0
    Adress 0x8101001c is 0x00000000
    Adress 0x81010020 is 0x00000000
    Adress 0x81010024 is 0x00000000
    Adress 0x81010028 is 0x00000000
    Adress 0x8101002c is 0x00000000
    Adress 0x81010030 is 0x000017a8
    Adress 0x81010034 is 0x00001340
    Adress 0x81010038 is 0x00000000
    Adress 0x8101003c is 0x00000000
    Adress 0x81010040 is 0x00000000
    Adress 0x81010044 is 0x00000000
    Adress 0x81010048 is 0x00000000
    Adress 0x8101004c is 0x00000000
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# hy1
    Adress 0xffe09000 is 0x8101004c
    Adress 0xffe09004 is 0x00000000
    Adress 0xffe0900c is 0x0013ffff
    Adress 0xffe09010 is 0x0400ffff
    Adress 0xffe09014 is 0x00020028
    Adress 0xffe09018 is 0x00000000
    Adress 0xffe09020 is 0x00000000
    Adress 0xffe09024 is 0x00000000
    Adress 0xffe09028 is 0x000cffff
    Adress 0xffe0902c is 0x00000000
    Adress 0xffe09bf8 is 0x02080203
    Adress 0xffe09c00 is 0x00000000
    Adress 0xffe09c04 is 0x00000000
    Adress 0xffe09c10 is 0x80044023
    Adress 0xffe09c20 is 0x000a0000
    Adress 0xffe09c24 is 0x00000000
    Adress 0xffe09c28 is 0x000a0000
    Adress 0xffe09c2c is 0x00000000
    Adress 0xffe09c30 is 0x8004401c
    Adress 0xffe09c40 is 0x00000000
    Adress 0xffe09c44 is 0x00000000
    Adress 0xffe09c48 is 0x000ffc10
    Adress 0xffe09c4c is 0x00000000
    Adress 0xffe09c50 is 0x8008800f
    Adress 0xffe09c60 is 0x00000000
    Adress 0xffe09c64 is 0x00000000
    Adress 0xffe09c68 is 0x00000000
    Adress 0xffe09c70 is 0x00000000
    Adress 0xffe09c80 is 0x00000000
    Adress 0xffe09c84 is 0x00000000
    Adress 0xffe09c88 is 0x00000000
    Adress 0xffe09c90 is 0x00000000
    Adress 0xffe09d00 is 0x000ffe00
    Adress 0xffe09d08 is 0x00000000
    Adress 0xffe09d0c is 0x00000000
    Adress 0xffe09d10 is 0x00044013
    Adress 0xffe09d80 is 0x000ffe00
    Adress 0xffe09d88 is 0x00000000
    Adress 0xffe09d8c is 0x00000000
    Adress 0xffe09d90 is 0x00044013
    Adress 0xffe09da0 is 0x000ffe00
    Adress 0xffe09da8 is 0x00000000
    Adress 0xffe09dac is 0x00000000
    Adress 0xffe09db0 is 0x00044013
    Adress 0xffe09dc0 is 0x00000000
    Adress 0xffe09dc8 is 0x00000000
    Adress 0xffe09dd0 is 0xa0f5501d
    Adress 0xffe09de0 is 0x000ffe00
    Adress 0xffe09de8 is 0x00000000
    Adress 0xffe09df0 is 0x80044013
    Adress 0xffe09e00 is 0x80020000
    Adress 0xffe09e08 is 0x00fdfea0
    Adress 0xffe09e10 is 0x00000000
    Adress 0xffe09e20 is 0x80000001
    Adress 0xffe09e28 is 0x00000800
    Adress 0xffe09e2c is 0x00000000
    Adress 0xffe09e30 is 0x00000000
    Adress 0xffe09e34 is 0x00000000
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# ast
    Adress 0x80020000 is 0x4ff09339
    Adress 0x80020004 is 0x04800007
    Adress 0x80020008 is 0x04800008
    Adress 0x8002000c is 0x00002000
    Adress 0x80020010 is 0xa0008001
    Adress 0x80020014 is 0xa0000000
    Adress 0x80020018 is 0x3e000000
    Adress 0x8002001c is 0x00000000
    Adress 0x80020020 is 0x00000000
    Adress 0x80020024 is 0x00000000
    Adress 0x80020028 is 0x00000000
    Adress 0x8002002c is 0x00000000
    Adress 0x80020030 is 0x00000000
    Adress 0x80020034 is 0x00000000
    Adress 0x80020038 is 0x00000000
    Adress 0x8002003c is 0x81810308
    Adress 0x80020040 is 0x0185bb5f
    Adress 0x80020044 is 0x00000000
    Adress 0x80020048 is 0x00000000
    Adress 0x8002004c is 0x00000000
    Adress 0x80020050 is 0x00000000
    Adress 0x80020054 is 0x00000000
    Adress 0x80020058 is 0x00000000
    Adress 0x8002005c is 0x00000000
    Adress 0x80020060 is 0x00000000
    Adress 0x80020064 is 0x00000000
    Adress 0x80020068 is 0x00000000
    Adress 0x8002006c is 0x00000000
    Adress 0x80020070 is 0x00000000
    Adress 0x80020074 is 0x00000000
    Adress 0x80020078 is 0x00000000
    Adress 0x8002007c is 0x00000000
    Adress 0x80020080 is 0x00000000
    Adress 0x80020084 is 0x00000000
    Adress 0x80020088 is 0x00000000
    Adress 0x8002008c is 0x00000000
    Adress 0x80020090 is 0x00000000
    Adress 0x80020094 is 0x00000000
    Adress 0x80020098 is 0x00000000
    Adress 0x8002009c is 0x00000000
    Adress 0x800200a0 is 0x00000000
    Adress 0x800200a4 is 0x00000000
    Adress 0x800200a8 is 0x00000000
    Adress 0x800200ac is 0x00000000
    Adress 0x800200b0 is 0x00000000
    Adress 0x800200b4 is 0x00000000
    Adress 0x800200b8 is 0x00000000
    Adress 0x800200bc is 0x00000000
    Adress 0x800200c0 is 0x00000000
    Adress 0x800200c4 is 0x00000000
    Adress 0x800200c8 is 0x00000000
    Adress 0x800200cc is 0x00000000
    Adress 0x800200d0 is 0x00000000
    Adress 0x800200d4 is 0x00000000
    Adress 0x800200d8 is 0x00000000
    Adress 0x800200dc is 0x00000000
    Adress 0x800200e0 is 0x00000000
    Adress 0x800200e4 is 0x00000000
    Adress 0x800200e8 is 0x00000000
    Adress 0x800200ec is 0x00000000
    Adress 0x800200f0 is 0x00000000
    Adress 0x800200f4 is 0x00000000
    Adress 0x800200f8 is 0x00000000
    Adress 0x800200fc is 0x00000000
    HT:[/secube]#
    HT:[/secube]# cat /proc/interrupts
               CPU0
     16:      15259    OpenPIC         Level        ast1200
     18:          0    OpenPIC         Level        fsl-ifc
     19:          3    OpenPIC         Level        fsl-ifc-nand
     20:          0    OpenPIC         Level        fsldma-chan
     21:          0    OpenPIC         Level        fsldma-chan
     22:          0    OpenPIC         Level        fsldma-chan
     23:          0    OpenPIC         Level        fsldma-chan
     28:        537    OpenPIC         Level        ehci_hcd:usb1
     29:        597    OpenPIC         Level        eth0_g0_tx
     30:       1614    OpenPIC         Level        eth0_g0_rx
     34:          0    OpenPIC         Level        eth0_g0_er
     41:         48    OpenPIC         Level        fsl-sata
     42:        683    OpenPIC         Level        serial
     43:         20    OpenPIC         Level        i2c-mpc, i2c-mpc
     72:          0    OpenPIC         Level        mmc0
     74:          0    OpenPIC         Level        fsl-sata
    LOC:      65936   Local timer interrupts
    SPU:          0   Spurious interrupts
    CNT:          0   Performance monitoring interrupts
    MCE:          0   Machine check exceptions
    HT:[/secube]#
    HT:[/secube]#HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# lspci
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# nova &
    HT:[/secube]# system("rm -f /secube/hotplug.result* > /dev/null 2>&1"); -> 0(Success)
    ls: /proc/scsi/usb-storage: No such file or directory
    system("touch /secube/startNova > /dev/null 2>&1"); -> 0(Success)
    killall: agetty: no process killed
    killall: login: Hidden chanBits=0xfffffffe currScreenMode=1
    no process killed
    system("diskcapa /dev/sda > /dev/null 2>&1"); -> 0(Success)
    system("rm -f /tmp/diskcapa.log > /dev/null 2>&1"); -> 0(Success)
    =========HDD OFFSET[0] : (r:0, w:0, m:1ce7d011e00)
    >>>>>>>>>>>>>>>>>>>>>> read fail(1):/dev/4 ?====
    =========HDD OFFSET[1] : (r:0, w:0, m:0)
    >>>>>>>>>>>>>>>>>>>>>> read fail(2):/dev/4 ?====
    =========HDD OFFSET[2] : (r:0, w:0, m:0)
    >>>>>>>>>>>>>>>>>>>>>> read fail(3):/dev/4 ?====
    =========HDD OFFSET[3] : (r:0, w:0, m:0)
    >>>>>>>>>>>>>>>>>>>>>> read fail(4):/dev/4 ?====
    =========HDD OFFSET[4] : (r:0, w:0, m:0)
    >>>>>>>>>>>>>>>>>>>>>> read fail(5):/dev/4 ?====
    =========HDD OFFSET[5] : (r:0, w:0, m:0)
    >>>>>>>>>>>>>>>>>>>>>> read fail(6):/dev/4 ?====
    =========HDD OFFSET[6] : (r:0, w:0, m:0)
    >>>>>>>>>>>>>>>>>>>>>> read fail(7):/dev/4 ?====
    =========HDD OFFSET[7] : (r:0, w:0, m:0)
    >>>> earliest: 268933876 747035044(268929765)
    >>>> latest: 268933876 747035044(268929765)
    ---------NO REC DISK---------
    ------------ ./conf/Black_352x240.264 Not Found -----------
    ------------ ./conf/Black_352x288.264 Not Found -----------
    ------------------------- initSideInfo --------------------------------
    >>>>>>> ENC VSYNC[0]-->4b668
    >>>>>>> VIDEO CODEC: ch:0 --> id:0
    >>>>>>> VIDEO CODEC: ch:1 --> id:0
    >>>>>>> VIDEO CODEC: ch:2 --> id:0
    >>>>>>> VIDEO CODEC: ch:3 --> id:0
    >>>>>>> VIDEO CODEC: ch:4 --> id:0
    checkUiThread : U/I Thread PID (1560) save
    system("/etc/rc.d/rc.smartd stop > /dev/null 2>&1"); -> 256(Success)
    sh: htb.init: not found
    Open Mouse Success : /dev/input/mice
    mouse initialize : 7
    initial read : 2 (0xfa030000)
    ******* eventScheduleTask: PID=1560 ... ******************
    >>> SET VGA vgaResol:21 index:2 name:[1920x1080p 60Hz]
    -------- AGT BIN HEAD  TYPE:BUF_ICON  MAGIC:current --------
     upload osg size wRatio:100, hRatio:100
    >>> bin magic:0x67ba36fd (bg:0, btn:0, btn3:0, img:11 w:725, h:960)
    -------- AGT BIN HEAD  TYPE:BUF_WIDGET  MAGIC:current --------
    >>> bin magic:0x67ba36fd (bg:4, btn:100, btn3:0, img:0 w:550, h:1100)
    -------- AGT BIN HEAD  TYPE:BUF_IMG  MAGIC:current --------
    >>> bin magic:0x67ba36fd (bg:0, btn:0, btn3:0, img:299 w:625, h:1160)
    Mdin380 Input Resolution : VIDSRC_1920x1080p60
    Mdin380 Output Resolution : VIDOUT_1920x1080p60
    system("/etc/rc.d/rc.smartd start > /dev/null 2>&1"); -> 0(Success)
    system("smartctl -A -H /dev/sda > /tmp/sda.rst"); -> 0(Success)
    system("rm -rf /tmp/sda.rst > /dev/null 2>&1"); -> 0(Success)
    Fail GetSystemString("COMMON", "Mtu", "MTU", buf, 50)
    Freeze chanBits = 0x0
    >>>>initOsgMmap: >>> mdinPciBase=0x4ed23000
    ------FILEIO_STA--------------------- ast1200AudioEncMode : 0
    RT-------------
    >>>> resetInputMediaBuffer: 1, 2
    ----------Clear Encoder Buffer--------
    >>>>>>> ENC VSYNC[0]-->4c83a
    ========== ---- videoEncMode=1, encChanBits=1
    FILEIO_RECORD_STARTFILEIO_RECORD_STARTFILEIO_RECORD_STARTFILEIO_RECORD_START
    system("rm -rf /mtd/upgradeLava > /dev/null 2>&1"); -> 0(Success)
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]# ls
    conf/      hdd1/      hdd4/      hdd7/      model      startNova
    driver.ko  hdd2/      hdd5/      hdd8/      nova*      web@
    hdd0/      hdd3/      hdd6/      hdd9/      ptz.dll*
    HT:[/secube]# df
    Filesystem           1K-blocks      Used Available Use% Mounted on
    /dev/root                23797     20740      1829  92% /
    /dev/mtdblock3           13312     11160      2152  84% /mtd
    HT:[/secube]# RR
    Mon Jan 17 13:42:58 GMT 2011
    Adress 0x10000061 is 0x00000000
    Build Date: 08:31:31, Aug  7 2012  HZ=250(23076)
    DriverInfoId=FM4411 MaxChannel=4(NTSC) MaxChip=1/1 MaxMem=1004MB
    AST-0: id=0x1200 revision=0 (year=2012 month=7 day=3) core=0/1
    Dec 0 DMA Buf: max=64(4MB) in=0 out=0 offset=0 size=0(0KB/0KB)
    Enc 0 DMA Buf: max=256(16MB) in=61 out=61 offset=0 size=0(0KB/256KB) FULL=0
    VideoEncMode=0x1 VideoDecMode=0x0 DmaRunning(DE)=01
    Video Enc DMA Rate (60s): 0.130 MBPS
    INTR-0: count=23283 (tick=23222 burst=61 enc=61 dec=0(0KB) codec=0 syserr=0)
    Dec 0 Info(Debug): DEC_Empty(Ex:In:Gf:Fr)=0:0:0:0 Act(Cd:Int:Ext)=0:0:0
                DEC_Size=0KB(0x0) FC=0 GodCnt=0 MinGodCnt=4
                DecControlReg=0x0040 DecCascadeReg=0x0010
                TimeStamp CH-0 Resol=HD 20100000 000000.000
    Enc 0 Info: F:E=0:1 VF:VE=0:0
                ENC_Size=0KB(0xf) FC=1 TS=0x0004f434
                BitRate(Mbps)=0.536(30,25):0.000(0,30):0.000(0,30):0.000(0,30)
    Mon Jan 17 13:42:59 GMT 2011
    Build Date: 08:31:31, Aug  7 2012  HZ=250(23329)
    Enc 0 DMA Buf: max=256(16MB) in=62 out=61 offset=0 size=65536(64KB/256KB) FULL=0
    Video Enc DMA Rate (60s): 0.132 MBPS
    INTR-0: count=23337 (tick=23275 burst=62 enc=62 dec=0(0KB) codec=0 syserr=0)
    Enc 0 Info: F:E=0:0 VF:VE=0:0
                ENC_Size=3KB(0x38) FC=1 TS=0x0004f82a
                BitRate(Mbps)=0.384(30,25):0.000(0,30):0.000(0,30):0.000(0,30)
    Mon Jan 17 13:43:00 GMT 2011
    Build Date: 08:31:31, Aug  7 2012  HZ=250(23583)
    Enc 0 DMA Buf: max=256(16MB) in=64 out=64 offset=0 size=0(0KB/256KB) FULL=0
    Video Enc DMA Rate (60s): 0.133 MBPS
    INTR-0: count=23398 (tick=23334 burst=64 enc=64 dec=0(0KB) codec=0 syserr=0)
                ENC_Size=0KB(0xf) FC=0 TS=0x0004fc21
                BitRate(Mbps)=1.096(30,25):0.000(0,30):0.000(0,30):0.000(0,30)
    HT:[/secube]#
    HT:[/secube]#
    HT:[/secube]#           --- system dead ( stop )
    Hi Elias
    Thank you for your kind support.
    One of my customer request is linux driver(2.6.35) for Xio2001 and refer to the below .
    >DVR : One board system
    >Main Chip : P1010(freescale)
    >Block parts : P1010 ( PCI_e port ) <-> Xio2001(PCI_e to PCI bridge ) <-> Ast1200 (codec chip : PCI interface )
     ; P1010(freescale), Xio2001A(Ti), Ast1200(customize codec chip)
    >Customer Request :
    1) Linux driver(2.6.35)
    2) Review of Log file :
    ->Adress 0x80010000 is 0x8240104c ; Xio2001
    ->Adress 0xffe09000 is 0x8101004c ; Ast1200
    She has some problem is Main CPU(P1010) and Xio2001 interface. And She doubt Software problem of linux driver.
    From Avnet-korea
    Eddy Lee (eddy.lee@avnet.com)
    1. The XIO2001 is a plain PCI bridge and is already handled by the Linux PCI core.
    2. What is the problem?
