XIO2001 PCI Configuration
Other Parts Discussed in Thread: XIO2001
Tech Support,
Customer is rying to bring up a new platform with the xio2001 under Linux, and running into a few questions about the bridge.
For example, we're seeing the following PCI configuration space:
21:00.0 Class 0604: Device 104c:8240
 Flags: bus master, fast devsel, latency 0
 Bus: primary=21, secondary=22, subordinate=22, sec-latency=0
 Memory behind bridge: 00100000-001fffff
 Capabilities: [40] Subsystem: Device 0000:0000
 Capabilities: [48] Power Management version 3
 Capabilities: [50] MSI: Enable- Count=1/16 Maskable- 64bit+
 Capabilities: [70] Express PCI/PCI-X Bridge, MSI 00
 Capabilities: [100] Advanced Error Reporting
00: 4c 10 40 82 06 00 10 00 00 00 04 06 00 00 01 00
10: 00 00 00 00 00 00 00 00 21 22 22 00 f1 01 a0 22
20: 10 00 10 00 f1 ff 01 00 00 00 00 00 00 00 00 00
30: 00 00 00 00 40 00 00 00 00 00 00 00 ff 00 00 00
We believe the 0x22 at offset 0x1e is the secondary status register.
This value seems to indicate that a master abort has been received.
But the bit never seems to clear, even though it appears to be a clear on read bit.
Are we interpreting this correctly?  And if so, why does the error bit never clear?
Mark Ackerson
Texas Instruments
Field Applications – MCU Products
(612) 991-1215 (Cell)
mark.ackerson@ti.com
  • Use "lspci -vv" to let the computer do the bit-fiddling for you.
    The secondary status register has the value 0x22a0.
    The master abort happend because the host probed for devices, and therefore tried to accesse the configuration space of some nonexistent device/interface.
    The master abort bit is write-1-to-clear.
