SN65LVCP418 Noise Susceptibility?
Other Parts Discussed in Thread: SN65LVCP418
All,
Have a customer with an Noise Issue using the SN65LVCP418 AC Coupled to a Quadrex (not twisted pair) Cable to transit DVI signals. The box and hardware of the system is well shielded and the cable connects to the main board through a transformer for lightning protection.
When an RF noise source is present near the cables (a standard test) the DVI signal is disrupted.
There doesn't appear to be a CMRR rating on the data sheet and doesn't appear to be enough information to derive it.
Any information you could provide on the CMRR would be greatly appreciated.
Joe Stramaglia - Avnet
  • Joe,
    If you take a look a the data sheet, figure 1 shows the ESD structure for the device.  If there is RF energy being conducted into the input pins at a frequency and energy level that is significant, those ESD diodes can rectify the noise to DC and cause a level shift.  I understand that the cable is sheilded, but I think the next best step is to try to quantify how much RF energy is getting into the signal path.  I suspect it is orders of magnitude higher than intended.
    As for CMRR, I don't see it in the data sheet either.  I think that CMRR will be largely dependent on the match between RT(SE) looking into the inputs.  If you have a board handy, it might be fastest to measure the resistance of the SN65LVCP418.  That way you'll also know how closely it matches in your exact test.
    Jake
