TFP403 LVDS PCB layout
Other Parts Discussed in Thread: DS90C387A, TFP403
After a great support by TI for my TFP403/DS90C387A schematic, I finished my PCB layout. Unfortunately it is my first board which uses LVDS (high speed signaling). I tried to consider all guide lines, like max length < 5cm , each pair with eqaul length and each pair nearly the same length. But now I am not sure if everything fits. One issue is the length of all QO and QE lines, they differ in worst case about 10mm, could that be a problem? I attached my layout 8080.LCD_controller_routed_complete_top_bottom.pdf. On the left side there is the dvi port an the dvi signal lines to TFP403, I use meander to get nearly the same length for the pairs is that bad? It would be very nice if anybody could take a look on my work.
Juergen
