NEED INFORMATION- SN75LVCP600SDSKR
Hi Can you please provide the following information for the SN75LVCP600SDSKR Part ?
1. Junction Temperature Max (Tj Max)
2. Typical Power dissipation (Pd typ)
3. Maximum Power dissipation (Pd max)
4. Weight
Jayakumara K
jayakumara.krishnasetty@honeywell.com
Tel:   +91-80-26588360   Extn: 50116
Honeywell Technology Solutions Labs Pvt Ltd.,
  • The data sheet has some of the information from page 5 on.
    I could not find it directly on the Ti site but did find it at http://www.alldatasheet.com/datasheet-pdf/pdf/463100/TI1/SN75LVCP600SDSKR.html
  • HI
    IN DATA SHEET FEW DATAS ONLY AVAILABLE
    Can you please provide me few more information for the SN75LVCP600SDSKR Part ?
    4. Weight
    Jayakumara K
  • Jayakumara krishnasetty said:
    HI
    4. Weight
    Jayakumara K
    1)  " typical values for all parameters are at VCC = 3.3 V and TA = 25°C; all temperature limits are specified by design "
    Also " TA Operating free-air temperature –40 85 °C " making max at 85 ( but not likely )
    2) – 106mW TYP (Active Mode @6Gbps)
    – <11mW (when link in partial/slumber state)
    3) now called ICCMax
    MODE/EQ/DE/SQ_TH = NC, K28.5 pattern at 6Gbps, VID = 700mVpp, (SATA mode) Typ 29 Max 41 mA
    MODE/EQ/DE/SQ_TH = VCC, K28.5 pattern at 6Gbps, VID = 700mVpp, (SAS mode) Typ 32 Max 45 mA
    4) Quality - Eco-Info & Lead-free (Pb-free):Content & Schedule Search Results. Device Mass ( mg) 15.2
    I would recommend what was part of the Datasheet under the Thermal Metric Section.
    " For more information about traditional and new thermal metrics, see the IC Package Thermal Metrics application report, SPRA953. "
