Channel Link II hot plug support ?
 Hello
Does the Chanel Link ser des, support the hot plug ?
I mean, can we deconnect the power supply of the serialiaser when he transmit some data. The link should normaly reconnect alone when repluging the power supply due to pattern (this is to use only one CAT 6 cable for the signal and the power suply, so we need to know if we can deconnect the cable directly or if we have to shunt down the power supply before.
bests regards
