Other Parts Discussed in Thread: TSS721A
Dear all
Does anybody has a schematic/circuit for a M-Bus Master Interface?
TI has a IC for M-Bus Slave.
Thank you
Best Regards
Marcos Olandoski
Dear all
Thank you
Best Regards
Marcos Olandoski
Marcos, while it's not my department, TI has an M-Bus transceiver TSS721A. In the data sheet are a few application schematic diagrams. Also the attached MSP430 apps-note has an M-bus application included.
Also a good M-Bus website is http://www.m-bus.com/default.php .
regards, Thomas
Dear Thomas
Thank you. But I already read all those information you had suggested. Everybody show you the slave interface, including TI, but you can't find any information about Master.
The TSS721A is a Slave IC.
Best Regards
Marcos Olandoski
Dear Marcos,
pleas take a look at:
http://www.solvimus.de/smart-metering/
There are module, level translators and gateways for M-Bus (master devices).
Please do not hesitate to contact me for further (and english) informations.
Remo Reichel.
You can implement the master by using a DC/DC booster. Connect your UART TxD to a transistor. The transistor drain connects the DC/DC Vref through a resistor to GND. So you have a permanent resistor that is connected in parallel with switched resistor from Vref to GND. In this way you have the Master M-BUS voltages. The UART RxD should be driven by current sense component i.e. current to voltage OP
