SN65LV1224B does not lock
Other Parts Discussed in Thread: SN65LV1224B, SN65LV1023A
Dear community,
we have a SN65LV1023A transmitter and a SN65LV1224B LVDS receiver. There is a fixed pattern on the serializer input and under some case the receiver does NOT lock.
We are aware of false lock and could accept that, but I could not find an information that the receiver does not lock at all. Is there a certain known input pattern which prevents the receiver to lock?
best regards,
Wolfgang
  • Hi Wolfgang,
    In the case when the receiver is not locking, what is changing? Is your Ref clock stable? Also, what does your pattern look like? In the case where there is a consecutive one zero pattern the device may take longer to lock because it is looking for a a start bit. You can try extending your time out to see if that changes anything.
    Mike
  • Dear Mike,
    at the moment we think the behaviour could come from too much clock input jitter on the serializer or the refclk jitter on the de-serializer or both together. We have PLLs on each side to generate the clock signal and we see different slight different behaviour if we change the PLL settings with the same clock. We could lower the jitter from 250ps to 150ps with different PLL settings and a different oscillator, but it did not disappeared. I will measure the receiver side later on.
    The timeout is some seconds and we did not see the LOCK coming after some time, if it is not locking.
    How will the serializer and de-serializer behave if the jitter is to high?
    Wolfgang
  • Hi Wolfgang,
    250ps of jitter is outside the spec of the part so I cannot confidently tell you how the part will behave in a situation like that. Try to operate the part in its recommended operating region and and see if you receive better results. Please follow back up with me so we can try to solve this issue. I look forward to hearing from you soon.
    Mike
  • Dear Mike,
    I have checked the input clocks on both side and both look fine now. Still we see that the receiver does not lock with a static input pattern like 0000000001b and no sync pattern. Is this a known behaviour?
    regards,
    Wolfgang
  • Hi Wolfgang,
    I am going to take an EVM into the lab today and try to duplicate your problem. Can you provide me with the specifics of your setup so that I can best match them in my lab?
    VCC, Data Pattern, Input Frequency, Jitter, ect.
    Mike
  • Hi Wolfgang,
    In order for the SN65LV1224B to lock one of two things has to happen.
    1. The synch pin on the SN65LV1023A needs to be toggled forcing the serializer to send 111111000000, allowing for only ONE 10 transition within the first twelve bit frame.
    2. The input/start-up pattern needs to avoid having a 01 transition to start with because the SN65LB1224B is looking for 10 to lock. It will see 1010 and sit idle not knowing what pattern to lock to.
    So you need to either toggle that synch pin or adjust your input pattern. Let me know how it turns out.
    Mike
  • Dear Mike,
    here is our setup:
    Transmitter SN65LV1023A
    SYNC1,2 = 0V
    DVCC, AVCC, TCLK_RF, PWRDN, DEN = 3,3V
    TCLK = 30Mhz
    DIN0-9 = 0111110001
    Receiver SN65LV1224B
    DVCC, AVCC, PWRDN, REB, RCLK_RF = 3,3V
    REFCLK = 30Mhz
    LVDS transmit pattern (it seems that the transmitter works correct):
    8468.LVDS Pattern small.tif
    So we have 2 0-1 transitions in our data. I was aware that this could lead to a false lock as this is mentioned in the datasheet.
    But that the receiver could not lock at all is new for me and not noted in the datasheet.
    best regards,
    Wolfgang
  • Hi Wolfgang,
    The 10 bit data is actually padded by the transmitter with a start bit (1) and a stop bit (0), so you actually get a 12 bit data stream at the desearilizer. So your D0-D9 data stream is actually 101111100010 which is causing you to sit ideal because there is three 10 transitions in that first twelve bit package. Try altering your first package so there is only one 10 transition or simply toggle the SYNC pin on the transmitter forcing the transmitter to send 1111100000.
    Mike
