TUSB2046B interface to 4 x ft245rl
Other Parts Discussed in Thread: TUSB2046B
2654.DS_FT245R.pdf
I am trying to use TUSB2046B to interface to 3 x ft245rl (pdf attached). can i omit the 27r resistors and 22pf capacitors normally required to terminate the downstream
DP and DM pins and drive the signals directly I will not be using power management of the TUSB2046B. DESIGN IS A SINGLE pcb with ftdi and TI parts.
Does upstram USB port need 75240. Is 2k2 AND 1 UF sufficiant for reset circuit
    We are reviewing your question and we'll reply soon.
    Regards.
    The 27 ohm resistors and and 22pF capacitors are indeed required. If they are not populated there is the risk to be non-compliant, these passive components are required by the USB spec.
    If the up-stream port is NOT going to be detachable the you don't need the ESD protection.
    A simple RC circuit is good for the power-up reset. Please see the RESET# terminal's description for timing requirements. (2k2 and 1uF sounds good)
    Regards.
