TL16C752C
Other Parts Discussed in Thread: TL16C752C
hi,
few questions regarding TL16C752C:
1. do i need to add serial resistors to data/address lines between the component and the MCU for impedance matching (or other issue i dont think of)?
2. regarding the clock value- what is the percent error difference between desired and actual? how is is calculated and how is it affecting the application?
3. i want to use high rate com, up to 1-1.5M . if i use a 25M clock - what is the baud rate i will get? if i use 16M clock, what is the baud rate?
