TMDS442 Signaling Rate
Other Parts Discussed in Thread: TMDS442
Hello
The datasheet of the TMDS442 states the following:
  • Supports 2.25 Gbps Signaling Rate for 480i/p, 720i/p, and 1080i/p Resolutions up to 12-Bit Color Depth
Due to the 8b/10b encoding, the effective data-rate is 1.8Gbps.
Is it correct that the TMDS442 supports all resolution/frame-rate/color depth combinations that end up with a rate below 1.8Gbps?
E.g.:
1920x1200p24, 24 bit per pixel
1920x1200p24, 30 bit per pixel
1920x1080p24, 36 bit per pixel
1280x720p24, 48 bit per pixel
