DP83848 pinos 3 e 4 nao respondem a ping
hello!
I use-DP83848 PHY and PIC32MX795 with router
 PING when I run on my PC the pins 3 and 4 do not have change
I can see the WIRESHARK appears as shown in the accompanying figure
How do I know if the DP83848 PHY-this 'talking' as PIC32MX795?
I appreciate any help.
Dagoberto
  • Dagoberto,
    Which DP83848 variant are you using?  Could you provide a schematic for review?
    Patrick
  • Thanks for the reply
    I ask your help to clarify whether the DP83848CVV  this working properly!
     I'm trying to make the circuit respond to a PING and is a server-page (same circuit-Ethernet Kit Microchip)
    I see:
    1) The pin 27 always on.
    2) The pin 28 always on
    3) The pin 26 off lights when transmission has
    4) The WIRESHARK shows Microchi_71: 90:69 ( This indicates that the PIC passed information to the DP83818  ?)
    I believe the DP83848 is working properly.
    I ask your help where should I focus on where (in DP83848)  to find the problem:
     example: 2,3,4 pins (TX) or 43.44 (RX)
    NOTE-1: I read your comments that pins 18.37 -> 23  should measure 1.87v. but has 1.5v.  how can I to make up to 1.87v?
    NOTE-2: The PIC   IP Adress: 169.254.1.1 MASK: 255.255.0.0 GATE: 169.254.1.1 DNS: 169.254.1.1
    MY PC:   IP Adress: 169.254.1.10 MASK: 255.255.0.0 GATE: 169.254.1.1 DNS: 169.254.1.1
    These data do not mean anything to see if the DP83848 is working properly?
    NOTE-3: Excuse my ignorance.
    1) If the WIRESHARK shows Microchi_71: 90:69 this means that the PIC 'talks' with the DP83848
       So the problem is that the DP83848 not 'talk' with PIC , or the PIC is configured \ programmed or problem in circuit PIC
    Dagoberto.
  • Patrick
    Sorry to have made so many questions, but I make the circuit work!!!! Now I see the PING and also the page is displayed.
    Among the many difficulties I highlight two:
     1) Incorrect address files for compilation.
     2) Force the setting 'Auto-Negotiation Modes' for 10BASE
    Thank you for your attention!! and Thanks
    Dagoberto
