Other Parts Discussed in Thread: DP83620
I'm using the DP83620 with the AFBR-5803 Avago transceiver. The datasheets for both devices indicates that they are PECL compatible. The reference schematic in the DP83620 datasheet (page 35) includes AC coupling for the TD+/- pair.
Why isn't it necessary to include AC coupling for the RD+/- pair?
I read the "DP83620 AC coupled?" question (http://e2e.ti.com/support/interface/industrial_interface/f/142/t/194096.aspx), and in that case, I can see AC coupling is needed due to the different logic levels, but could somebody please explain why it is needed for the AFBR-5803 (same transceiver on the Eval board) and if so, why only on the TD+/- pair?
Alex
