Other Parts Discussed in Thread: TUSB9261
Figure 2 in the TUSB9261 Implementation guide is called "Example Crystal Implementation", and has VSSOSC connected to ground.
Under section 6.1 of the TUSB9261 Data Manual, second paragraph ends with "The VSSOSC should not be connected to PCB ground when using a crystal". Figure 6-1 shows a "typical crystal connection" with the crystal load capacitors connected to VSSOSC instead of ground.
Which is correct?
Erland Lewin
Avalon Innovation AB
Stockholm, Sweden
