RS-485 Pull up resistor
I read in order to maintain a solid reading from the pins A and B of the RS-485, I need to attach pull up and pull down resistors for "fail safe biasing".
Therefore, I have attached a 360 ohm resistor from Vcc to A and a 360 ohm resistor like I saw in an example, and from B to Ground and I am unable to read the output.  How did I incorrectly apply this?
    I responded to your other post about this, and so I believe 360 Ohms may be too strong of a failsafe value. It violates the equation 2 from this app note:
    http://www.ti.com/lit/an/slyt324/slyt324.pdf
    The maximum common mode resistance from the RS-485 standard is 375 Ohms. This may be why you are having issues, I am not sure.
    Try re-calculating the failsafe values, or simply remove them.
    Jason
