DP83848J application question
Other Parts Discussed in Thread: DP83848J, DP83848C
Dear Sir
Good days,
We have use DP83848J(MII)  POS machine and we have to ping, we can ping 100M , but we can't ping 10M.
May you have some suggestion for us or may you have DP83848J initial code or register set up value can advise us?
We have try to use NXP  MAC  EVB(EVB is DP83848C  on EVB). it can ping100M and 10M.
        Bogey
  • Hi Bogey,
    I apologize this question never got responded to.  I am also going to move this question to the Ethernet forum where if can be properly supported and tracked. Please post your future Ethernet PHYs, Ethernet MACs and Ethernet SerDes questions to the Ethernet Forum.
    Thanks!
    John
  • Hi Bogey,
    The ability to ping comes from the MAC. once the PHY established link, its role is over.
    you mentioned that in 100M link you can ping but in 10M you can't.
    Did you evrified you established link in 10M mode?
    How does your setup looks like? do you use ANEG for 10M link establishment? for this you need to configure the PHY to atop advertise 100M, in order to establish only 10M.
    Do you use HD or FD?
    Thanks & Regards,
    Oren
  • Dear Sir
    Many thans for your reply, after co-work with customer. the issue already sovle that sofeware issue.
        Besr regards,
        Bogey
