DS90C241 interfacing to Sony displays
Other Parts Discussed in Thread: DS90C241
I need confirmation that the DS90C241 transmitter, and it's related devices, will interface seamlessly with Sony displays that use their CXB1466R (older part) and CXB1458R and other Sony GVIF receivers.
Thanks.
  • I was unable to locate detailed info for the Sony GVIF Tx and Rx devices. Based on the Sony product briefs and GVIF White paper, I found the following:
    - Sony GVIF is 400 mV diff. signal levels w/DC balancing much like TI device LVDS outputs
    - Sony GVIF is employs NRZ encoding at the Tx and our device Data Sheet does not indicate NRZ encoding.
    - Sony GVIF Tx operates to 1.2 GBPS rates, TI device to 840 MBPS
    - Sony GVIF Tx is 24 bit parallel LVCMOS in like TI device
    - Sony GVIF Tx shift clock f range is 7.6 - 42 MHz, TI dvice is 5 - 35 MHz
    - Sony and TI devices use 3.3 V supply
    - Sony GVIF devices operate over Ta = -40 - +85 deg. C, TI devices: -40 to +105 deg. C
    So, it looks like the TI Tx device will not interoperate with the Sony Rx device. The main problem is the NRZ coding for the Sony Tx.
