Phy Compatibility
Other Parts Discussed in Thread: TLK1501, TLK1221
I am looking at a new product design which takes in 10GB Ethernet and distributes to a number of other elements.
Current plan is to use a TLK2208 or equivalent on the main board talking to a series of TLK1501 at 1.2GB. It looks as though the 2 sides of the equation are compatible, but only one side refers to 802.3.
Anyone any experience of using this type of pairing?
Jim
  • Hi Jim,
    It is unclear to me what you are attempting to do in this design with the parts that you have selected to use. The TLK2208 supports 8 ports of gigabit Ethernet, not 10 gigabit Ethernet. Are you just trying to see if you can get a gigabit serial link up between TLK2208 and TLK1501?  If so, one issue with the TLK1501 here is that, while it supports 8b/10b encoding, it doesn’t have the full control code set specified in 802.3. Here is a thread for reference: http://e2e.ti.com/support/interface/high_speed_interface/f/138/p/96931/338828.aspx#338828.
    Are you looking for more of an agitator type SerDes device that will take several low speed lanes and aggregate them up to a 10 Gbps link and perform the opposite operation?
    Mike
  • Hi Mike, thanks for the reply
    The systems will have a 10GB link to a PC and demux this to 8 channels running at 1MB, so I was looking at the 2208 to drive the individual channels. We already have USB2 and USB3 version of this and I am looking at the next gen. The 2208 drives 8 channels and I was trying to find a compatible single (in fact I probably need dual) channel phy for the remote end:
    PC -> 10GB ->  PCB -> 8 x 1GB -> 1GB in and out.
    Hope this helps,
    Jim
  • HI Jim,
    Is your application going to implementing Base-T signaling or Base - X? The TLK2208 is intended handle the BASE-X interface type, which is used to transmit NRZ signals over optical fiber, balanced copper twinaxial/coaxial cabling, or copper backplanes. If 1GbE Base-X will work for your application, then I would look at TLK1221, TLK1201A, or TLK2210B for the single channel solution and TLK2218 for the octal. I suspect TLK1221 would be the cheapest solution. There may be some other solutions that we can recommend here once you clarify for me if the application is Base-T or Base-X?
    Mike
  • Hi Mike
    I was initially looking at the physical layer so hadn't considered the 2 options. We currently use LVDS @ 300MB using serdes and our own protocol. For the GB we could use our own protocol over an existing physical layer but it would probably make more sense to use a standard even if it is not quite as efficient.
    We certainly need to isolate the 2 ends and we currently use CAT6A so I am thinking the 1000BASE-T looks the more obvious choice?
    ATB
    Jim
