Other Parts Discussed in Thread: SN65HVD232, SN65HVDA541-Q1, SN65HVD256
I am creating a new design for a CAN data logger. Our old device is 5V and uses a Microchip MCP2551 (5V). Due to an architecture change, I would like to eliminate the 5V supply and use 3V3 instead.
I have worked with the TI SN65HVD232 in the past and would like to use this device again. However, I wish to keep a special function of the 2551: the ability to ground CANL and use the transceiver in single-wire mode. I tested this with the SN65HVD232 and received BUS OFF errors any time I took the module out of sleep.
Are there any (SOIC-8) 3V3 transceivers by TI that would allow this function? Alternatively, would anyone be able to suggest a "conversion" circuit that could be switched on / off with a jumper with minimal BOM impact? The maximum data rate in SW-mode is 33.3kbps, and 125kbps in dual-wire mode.
Thank you!
