DS64MB201 - Tj(MAX)
Guru 19785 points
Other Parts Discussed in Thread: DS100MB203, DS64BR401, DS64MB201
Hi, could you please let me confirm about the Junction Temperature description in the datasheet ?
In the datasheet P.5 Junction Temperature Range is said as "+105C" for  TJ(MAX).
Isn't this a typo ?
I think 125C would be correct.
Family product of DS64BR401 and DS100MB203 have TJ(MAX) = 125C in the ABS MAX Ratings.
Kawai
  • Kawai-san
    I would tend to agree with you that 105C is probably a typo - the max operating condition is 85C ambient, theta JA is almost 20C and power dissipation is about a watt which means that junction temperature under normal, recommended operating conditions could be very close to 105C.
    I will verify with some of the development team, but I would assume that the Abs Max junction temp is 125C.
    Mark Sauerwald
  • Mark-san,
    Thank you for your reply.
    I believe that TJ(MAX) is 125C, but please give us the final answer after verifying the developping team.
    Kawai
  • Mark-san,
    Have you verified the developing team ?
    We need the information for the customer to make decision.
    We're looking forward to hearing from you.
    Kawai
  • Kawai-San,
    I confirmed as Mark-San mentioned maximum junction temperature is 125 Deg C.
    Also, min/max supply is not mentioned in DS64MB201 data sheet. Please use DS64BR401 as guideline to get max junction temperature and other parameters(like min/max supply).
    Regards,,nasser
  • Nasser-san,
    Thank you for confirming to the designer.
    We have requirement from customer to correct typo on the datasheet.
    Could you please revise the datasheet.
    Kawai
