TL16C752C Vs. TL16C754C, SW compatibility Question
Garmin has the following question:
Can you confirm that TL16C(P)752C and TL16C(P)754C are equivalent from a software perspective (excluding DMA capabilities)?  It looks like one is just the dual and the other the quad, but I want to make sure before moving forward.
I reviewed the register sets, and they look the same from that perspective.
Thoughts?
Mark
  •  Hi Mark,
    I moved your question to this forum so that the proper people can help you with it. Please post your future UART questions in the forum. We are working on updating the forum descriptions to reflect this change.
    Sorry for the delay with getting the question to the correct people.
    Thanks!
    John
  • Hello Mark
        Indeed, both devices could be seen as software compatible, since the configuration registers are the same for each channel, therefore the difference arise on the way to select the desired channel.
    Diego.
