TCA9509 Output Current Specification
Other Parts Discussed in Thread: TCA9509, TCA9517
TI Team,
I'm using the TCA9509 is a mixed voltage I2C bus. I have 3.3V on the B side and 2.5V on the A side. The datasheet specifies a 10uA low level output current. However, the datasheet says the A side has a strong pull down resistor of 200 ohms. For a low voltage output of ~.2V, wouldn't this imply a 1mA low level output current? How do you arrive at 10uA? Can you share the driver structure for both the A and B sides?
-David
