DP83848i transformerless with small capacitors
Other Parts Discussed in Thread: DP83848I
I am working on a board with a lot of PHY (DP83848i) and I am trying to cut the price down by replacing transformers by capacitors. However, due to safety constraints, I have to use smaller Y capacitors value (<33nF) than in the AN-1519. To be honest I didnt fully understand the Appendix A: Calculating the Minimum recommended Capacitance and therefore I am wondering if I could customize the solution by adding resistors?
Thank you,
Rémy
  • Hello Remy,
    Could you share some more information regarding your project?
    Such as:
    How many DP83848I PHYs are on your board?
    Also, what safety constraints are of concern to you?
    John
  • John,
    There are 7 PHY and 3 switch from Micrel (I cant change that, I'm not the designer), which is transformerless capable too. All of these are using many transformers. They are big and cost money.
    So we thought we could replace them by capacitors, which are much smaller and cheaper. I actually started to test with 100nF and so far it is working just fine. However I have been told recently to use Y2 capacitors. I cannot provide you the design of the board but it is seperated in sections which are supposed to be independent (it's a "safety board", I'm working in a railway company). Sadly these Y2 capacitors are expensive (100nF are around 1€). That is why I was wondering if I could use smaller ones (~20nF) somehow?
    Rémy
    ps: I included the tests I have done so far. It's very basic but I'm still working on it.6646.transformerless_basic_test.zip
  • no news means no solution? Well, I can try by myself by I would like to have an official opinion on this!
  • In the App Note AN-1519 the minimum value of 33nf is specified in order to remain compliant with IEEE and ANSI standards.
    The App Note AN-1519 also recommends that the PHY be operated in Forced 100MB mode, From the waveforms provided
    in your transformerless_basic_test.zip file I see that some of your  tests are in 10MB mode, not recommended.
