Other Parts Discussed in Thread: SN65LVCP408
I am planning to use SN65LVCP408 with a 3G-SDI receiver in my system in a 8 input and 4 output configuration. I am planning to connect them in AC coupling mode so that the Common mode voltage requirements will be taken care of. However I am seeing that the output voltage differential swing ranges of SN65LVCP408 do not match with the input voltage differential swing of receiver.
The datasheet of SN65LVCP408 mentions that the output differential swing range is from 1000 - 1500 mVpp. Whereas the receiver input differential swing range is from 500-1100 mVpp.
Can anyone help me out in resolving this issue?
I am in the closing phase of my design and any quick help will be really appreciated.
Ayusman
