DS15BR400 and Clock
Other Parts Discussed in Thread: DS15BR400, DS100MB201
Dear Sir
We want to use DS15BR400 to design LVDS repeater ,the cable length will be 300mm ,but I want to ask ,How about differential clock signal
Should I need to add a clock buffer or not?
Do you have any solution of clock that you recommend ,and this solution had already used in real project or product
  • If you are looking to buffer a clock after it has gone through 300mm of cable, the DS15BR400 would be a good product - but it is a buffer with one input and one output per channel.   If you are looking to generate additional copies of the clock, then some other products that you might want to look at would include the DS100MB201, or the DS10CP154.
