Other Parts Discussed in Thread: TPD2EUSB30A, TPD4E002, TPD4E1U06
We have a customer with some FPGAs damaged by ESD they believe. They say:
"We are using the TI TPD2E009DRTR 2-CHANNEL ESD SOLUTION FOR HIGH-SPEED (6 GBPS) DIFFERENTIAL INTERFACE on our SATA drives and have seen some blown FPGA transceivers on RMA units which we believe is due to ESD events.
We put the parts on a curve tracer and the clamp doesn’t seem to kick in until near 12 Volts. Why is it set to clamp at such a high voltage for differential signals that should never exceed 2 Volts per the SATA specification?."
Can you suggest some reasons the customer is seeing a VBR over 12 volts when it should be 12V. I have let them know the TPD2EUSB30DRTR is identical except VBR is 4.5V.
Thanks for your help.
