Other Parts Discussed in Thread: SN74ALVTHR16245
The SN74ALVTHR16245 is a bustransceiver with switchable data direction.
The DS recommend to not use a pullup resistor to data inputs. Reason is the active bus-hold circuity.
Question: does this affect also the DIR inputs?
If yes, how you can set the DIR pin to fix value, with or without a pull down/up resistor?
