Other Parts Discussed in Thread: DP83849IF
Hi all.
DP83849IF has I/O 3.3V Supply and I/O Ground, Analog 3.3V Supply and Analog Ground. As I know, common practice - have IO and Analog ground the same plane, not two one point tied polygons. In second case I have questions below...
First, Core Ground - what ground it should be routed to, IOGND or ANAGND?
Next, CD Ground - the same question (and what is CD stands for?).
More, Power Feedback Input/Output - what ground bypass capasitors should be connected to?
Then Bias Resistor Connection - the same question as above.
Does anybody can make it plain?
Regards, Serguei.
