Inquiry regarding TL16C550D system configuration
Hello, all
Now we are designing our system with TL16C550DIPFB, then would like to clarify whether our configuration is correct.
Please see the enclosed file, and feedback us with your comment.
(I apologize that full schematic is not permitted to disclose on this thread. I would be able to send that only by e-mail.)
If you need further information for the detail, please feel free to ask me.
We thank you in advance for your information.
3005.Inquiry regarding TL16C550DIPFB system configuration.doc
  • Hello Atsushi,
    The configuration described seems to be correct, I only have one question and one optional suggestion :
    Q: What do You mean with in the point 8 "The baud rate per one UART is commonly set on both transmission and reception"?
    S: I would rather to use small capacitors in order to connect to GND the signals /CTS, /DCD, /DSR and /RI.
    Diego.
  • Hello, thank you for your prompt reply.
    With regard to your inquiry of point 8, please let me inform you as below;
    This means that per one UART channel, if transmit side select 9600bps, receive side also select 9600bps, not select other baud rate.
    Thank you once again for your confirmation.
