Other Parts Discussed in Thread: DP83620, DP83640
Hi Everyone,
Does anyone know if the dp83620 will work with either the generic Linux PHY driver or the national driver which is for the dp83865? Has anyone used this device with LInux? Thanks.
The DP83620 should work with the generic Linux MDIO driver for basic Ethernet functionality. I have not tested the DP83620 explicitly, but the DP83848 shares the same basic IEEE register set as the DP83620 and has been tested to verify the functionality.
Patrick
HI Ross
Now I want use 'dp83620' in a linux system,but without it's driver,i have 'dp83640' driver, Can not be modified to use on 'dp83620'
can you help me.
Thank you
Tracy
Hi Ross
Thank you for you reply,I tried the file you gave me,but undefined symbol,I use linux embedded system,
it have been tailor,I doubt is this reason cause can not compile
can you help me or give me some suggest
Thank you
Tracy
