Do we have AVDD, DVDD, PLLVDD supply current spec. of XIO2213 that can be provided to customer? Thank you.
Patrick
Patrick
Hello Patrick,
Please send me an email with the customer and application information.
Diego.
diego.cortes@ti.com
Hello Diego
Do you have any update or comments for above question?
BTW, we have another question at XIO2213 reference schematics. The bilingual connector looks separate another ground from others ( AGND & DGND). If just only connect to single ground, does it have any impact ? Thank you.
Hello Patrick,
For proper operation of the XIO2213B, we recommend a unified VSS and VSSA ground plane. The circuit board stack-up recommendation is to implement a layer 2 ground plane directly under the XIO2213B device. Both the circuit board vias and ground trace widths that connect the VSS and VSSA ball pads to this ground plane must be over sized to provide a low-impedance connection.
Diego.
