Dear, All
In a customer's system, MPU's UVLO operates less than 3V.
Then, even after the UVLO of Vcc of SN65HVDA1040-Q1 operates, the MPU operates.
There are the following questions from a customer.
- When the UVLO of Vcc operates, does RXD pin stop operation?
Does a logical output serve as 'High' then?
- Does hysteresis stick between rise edge and fall edge of a power supply about threshold of UVLO of Vcc?
When attaching, how Volt is it generally in a typical value?
- About TXD Dominant State Timeout.
I want you to teach the release method after TimeOut occurs.
Thanks, Masami M.
