Hello!
It is necessary to disconnect RS485 segment, if fault condition (for example, short) is detected. Operation of the full system should not be stopped in this case. What are common approaches for solving this problem? I plan to use a closed loop with two RS485 ports on Master device. You will find illustration in the attached document. Or do all Slave modules need to integrate this protection mechanism?
Dmitrij
