Other Parts Discussed in Thread: LMH0340, DS30EA101, LMH0394, LMH0384
We have recently prototyped a design incorporating the LMH0340 serializer. The SDI output is designed as follows and connects to a 75 ohm coaxial output jack:
I want to pass the output of this circuit over coaxial cable to another PCB (approx 10cm cable length). I'll be using the same 75 ohm coaxial jack to receive the signal but I want to convert the SDI signal received to a differential signal (LVDS).
Can you tell me if the DS30EA101 adaptive equalizer IC is the correct component to incorporate onto my second PCB to accomplish this task or what complications could occur if I just try to use a Balun?
Thank you,
Fearghal
